Pro Tools 10 won't work on Mac El Capitan 10.11.6
Hello,
I was wondering if you could help me out. I recently had an issue with my mac hard drive and had to re-install OS El Capitan 10.11.6. I had to wipe my main bootable hard drive but I had an old hard drive which I keep my original Pro Tools 10 on. I had also found another download of an updated version of Pro Tools 10 which was Pro Tools 10.3.9 dmg. When I tried to install it again it came up with a message basically saying it doesn't recognize my operating system, which is strange because it worked on the same OS before my old hard drive crashed. Is there a link on your Avid website that you could link me to which has a compatible version of Pro Tools 10? I still have my ilok key inserted. Thank you kindly for your help Luke |
Re: Pro Tools 10 won't work on Mac El Capitan 10.11.6
There is no supported version of PT10 for El Capitan.
https://avid.secure.force.com/pkb/ar...tibility-Chart Saying you had it running before was pure luck. I suspect you had an older macOS and did an in-situ update to a later macOS and fortunately for you, it continued to work. Definitely not a supported config as can be seen by the compatibility chart I posted above. Sent from my iPhone using Tapatalk |
Looking at the compatibility chart here, Protools 10.3.9 requires:
OS X Snow Leopard (10.6.7 - 10.6.8) OS X Lion (10.7 - 10.7.5) OS X Mountain Lion (10.8, 10.8.2-10.8.5) and therefore will not run on El Capitan. Likewise, El Capitan (specific versions) only worked with Protools 12.3 through 2018.12
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
It works fine on Maverick (10.9). Tried it on yosemite with no success.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Protools 10 has an OS Check in the installation Package which prevents the installation on a newer MacOS.
You need to change OS Check in the distribution file. Google for "Installing Protools 10 on Macos Sierra (the right way)" There is very good tutorial video how to edit the Protools 10 Installation Package to make it possible to install PT10 on newer versions of Macos... Good luck |
Updating from El Capitan to Mojave, will PT 12.5 work? | Kerochan | Pro Tools 12 | 4 | 02-29-2020 06:20 AM |
STOP trying to make El Capitan work! | Intransit | Pro Tools 12 | 70 | 05-17-2016 05:46 PM |
will PT 11 ever work with El Capitan? | slideguitarguy | Pro Tools 11 | 43 | 04-01-2016 12:50 PM |
Final word- does Mbox 3 PRO and El Capitan work? | postprosound | FireWire & USB Audio Interfaces (Mac) | 0 | 03-11-2016 07:18 AM |
MBox/El Capitan work-around for $9.00 | Ormond | FireWire & USB Audio Interfaces (Mac) | 0 | 12-20-2015 05:15 PM |
