Logic 7 and Protools Mix Systems Incompatability
I have Just tried to get Logic 7 running on my Mix cube system under the latest 0s 10.3.6 with latest version of tools 6 and it will not run any audio instruments. Can anyone tell me if digidesign plans to fix this as I am not very happy. I dont want to hear "you need a HD system" as I do not. I am very happy with my Mix Cube with an extra mix farm in a magna chasis with an AD800, 1622 and two 888/24's. Has anyone else expierienced the same issue???. As a power Logic User I am not alone using this config and am blown away by the latest Logic 7 pro but I can only run it on my laptop. I recon there must be quit a few thousand people in my boat.
Ricky Pann |
Re: Logic 7 and Protools Mix Systems Incompatabili
By "audio instruments", you could be referring to at least four different items:
1. native-based Direct TDM (DTDM) instruments (including ReWire) with the Emagic System Bridge (ESB), or, EXS24 TDM 2. native-based Host TDM (HTDM) instruments (e.g., EVP88 + Host TDM authorization on XSkey) 3. TDM plug-in instruments (hosted on a DSP chip, e.g., Virus Indigo or Emagic ES1 TDM) 4. native-based Real-Time AudioSuite (RTAS) instruments [supported only by Pro Tools 6.x, and I believe, Digital Performer 4.5 as well, but not by Logic] I've never had any problems with items 2 & 3. Item 4 is questionable, as I CAN get an RTAS instanciation of Native Instruments FM7 to produce sound when triggered from its own keyboard, but no MIDI output to the plug-in appears to Logic, as with items 2 & 3. I have frequently had problems with item 1 (ESB TDM / EXS24 TDM), though I have traced this back to two things: A. one must use the 32-voice playback engine, not 64-voice (this is indicated in the white TDM manual included w/ Logic Pro 7) B. one ABSOLUTELY must de-instanciate each and every ESB output (DTDM objects assigned to ESB outputs) and input (DAE objects having an ESB input) after re-arranging interfaces across cards, then save song file and re-boot the machine. Item B really killed me while recording ten channels of live drum tracks during a recent overdub session: none of the existing Direct TDM instruments would work as previously, though I had recently re-ordered the interfaces. The trick above (common sense to some) worked, and I have been tracking without problems since. Whew! The upside of this is that I'm less likely to ditch TDM altogether on the "big system", which has a lot of legacy MIDI modules attached into two 1622 interfaces, among other things. And I do enjoy mixing in Pro Tools, for what it DOESN'T allow me to do on the MIDI side, forcing me to listen. But the music-making capabilities of newer Apple hardware (e.g., iMac G5) running plug-in instruments natively, with Logic's Freeze function, are hard to beat. Methinks I will have both worlds available to me. |
Re: Logic 7 and Protools Mix Systems Incompatability
Hello Ricky,
Are you running logic under coreaudio? or DAE for TDM? If you're running under DAE you will have to install the Emagic system bridge (ESB) this will enable you to run audio instruments from the logic mixer and then route them into the DAE mixer. OS 10.3.6! who reccomended this? digi haven't qualified it yet! what about appleMagic!! perhaps you could give more specific detais of your setup and people could help more. Regards Chris
Thanks man I seem to have it going now, and it seems to be working, I think I might try going back a few verions of osx. I will spend tomorrow testing but I now have all my logic instruments going and my AU instruments are working to. The 32 voice mode got it going and when I turned off core audio it seemed to be more stable. Thanks for the help.
Ricky
Ricky Pann |
By the way, I'm running a PT Mix Cubed + DSP Farm in an 1,25Ghz G4 (only OSX Boot) with Logic 7 and OSX 10.3.4. It works perfect. I have installed ProTools 6.2.2 on my System and it's running also perfect with my Mix Cubed.
protools and imac incompatability | glocke12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-19-2010 04:53 AM |
Logic Express and ProTools HD Systems | Mr Rian | Pro Tools TDM Systems (Mac) | 0 | 11-23-2009 11:36 PM |
Mtools and Protools 7.2 Incompatability | david liversidge | Post - Surround - Video | 17 | 09-18-2006 03:51 PM |
how does logic Work with Le systems ? | mersisblue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-24-2004 11:19 AM |
Logic audio support for pro tools H.D. systems | alexmorris | Pro Tools TDM Systems (Mac) | 3 | 03-24-2002 04:02 AM |
