Old 02-19-2021, 08:31 AM
asgard1019 asgard1019 is offline
Default Spinning ball after open session
Hi guys, this is a strange situation.
When I open a session, restoring tracks bar has done. Edit window pop up.
Spinning ball start to run around 6-8 minute and system usage meter won't show anything. I can't do anything on PT.
After PT had load everything (I don't know what it is loading). System usage will show the meter.
I tried press shift to deactivate every plugin and activate one by one, found two need to take a while so I remove those two. But it's the same when I quit PT and open again.
This is happening on my other arranging session, mix session it's not affected. Same VI as I used, just happened suddenly few days ago.
Any solution?
PT 2018.12
OSX 10.12.6
Old 02-19-2021, 08:46 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Spinning ball after open session
Your PT/OSX combination is supported, but when did you update your plugins? That is relatively old system so in case you have updated some VI lately, that may be a problem if it is NEWER than your OS. So take a look at all your plugins and their versions, you may need to ask some plugin vendor to send you OLDER versions that work well with your OS.
Janne
Old 02-19-2021, 09:11 AM
I hadn't update my VI or plugin , It's all the same old VI/plugin I used before. Just happened like this.........So I'm so confused.
Old 02-19-2021, 09:26 AM
JFreak's Avatar
Try to figure out what was changed since it last worked
Janne
Old 02-19-2021, 06:06 PM
As far as l remember, nothing changed since I start this session. Or include the plugin doesn't use in this session ?
I forgot mention when ball is spinning, cpu usage is around 110~160%. I create a test session, add 12 tracks to insert Kontakt with Red Room Orchestral . It seems like Kontakt is loading VI, but it can't load on background so freeze PT to focus load VI.
Old 02-20-2021, 04:12 AM
JFreak's Avatar
Doesnt matter if plugin is used in session, it will be loaded into memory anyway. ANY ONE bad plugin may cause random problems
Janne
Old 02-21-2021, 07:10 AM
It's the same to remove the plugin add recently. And found this thread is similar with my situation.
http://duc.avid.com/showthread.php?t=408645
Enable kontakt memory manager and it really worked ! Although it would spinning about 30s after open session. But it help a lot.
Spinning ball when... SomeOtherGuy Pro Tools 12 1 03-27-2017 11:08 AM
Spinning ball problem in PT 11 OSX AndreasvanHaren Pro Tools 11 4 08-19-2015 04:22 AM
Spinning ball when I try to sync to Ext W/C SoundMoves macOS 11 06-24-2011 08:34 AM
Spinning ball Mubeau Post - Surround - Video 5 08-15-2006 11:42 AM
Spinning ball at stop Faux Pas Pro Tools TDM Systems (Mac) 2 03-12-2004 04:38 AM
