Old 05-16-2021, 11:54 AM
BLG BLG is offline
Default Using output 3/input3 on my Focusrite to send/return
I'm trying to use PT and my Focusrite 4i4 interface to send a guitar signal from one track to a wah pedal and then back in to record on another track. So I set the output of the original track to Output 3 (Outputs 1 & 2 go to my monitors) and then put that into the wah and the output of the wah I plug into input 2. But all I get is a high-pitched whine. I tried putting the output into my amp and the correct signal is being sent so I know I'm sending the signal right - it seems to be the return that's messed up. What am I doing wrong? This is my first time attempting to use any outboard gear.
I also tried going from the out into the wah and then into the amp and micing the amp but I'm getting a lot of feedback even with the monitors off, so no idea what's going on there. I even get feedback when I turn off the mic(?).
Old 05-16-2021, 12:15 PM
Default Re: Using output 3/input3 on my Focusrite to send/return
The noise you describe certainly sounds like feedback, and I suspect a feedback loop is happening. Give that the Focusrite probably has some routing utility going on in the background, I'd start by checking that for a problem(because your connections seem to be correct).
Having said that, most guitar players I know(including myself) would simply use the wah pedal on the way in instead of afterwards. Otherwise, I would try a plugin wah pedal(Amplitube has several)
Old 05-16-2021, 05:36 PM
BLG BLG is offline
Thanks Dave. I was trying to dial in a wah that I couldn't quite get while playing but that may be the ultimate answer. I'd still like to get the send/receive working though as it's a model for processing out of the box.
Old 05-16-2021, 06:09 PM
I haven't done this but my understanding is that the output from you interface (Scarlet 4i4) is line level. The wah pedal operates at instrument level as does a guitar plugged into an input. The preamp on the input can compensate for the difference in levels so that you can record instrument level into the track. The problem I see is that a line level signal coming out of your interface is not adequate to drive the wah pedal's input. Wah pedal inputs are finicky in that they interact with the load from the guitar's pickups. Since you interfaces output will not have the similar pickup loading, the wah will not respond as desired. Often to do this type of setup (out from the interface for instrument level processing and back into the interface) you would need a reamp type device. Radial makes some devices specifically for this purpose. I hope this helps.
Obsidian Dragon
Mac Studio M1Max - 64GB
Focusrite ISA 428 balanced insert send and return tripstation General Discussion 4 01-02-2010 12:51 PM
002 SEND RETURN INSERT OUTPUT INPUT PROBLEM!!!!! Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-19-2007 12:19 AM
send/return RogerJeep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-01-2006 09:07 AM
Bus: Send / Return bassbuddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2005 10:51 AM
Send and Return Spam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2000 10:30 AM
