Old 11-08-2010, 09:44 AM
danika danika is offline
Default Delay Compensation
I must be making some basic mistake on applying delay compensation. I have short delay enabled, and the system delay shows as 1024 samples. To test delay compensation, I inserted 5 AIR plugins (reverbs, pitch shift, etc.). However, the Delay Compensation View shows no delay and no compensation. That doesn't seem right.
Old 11-08-2010, 10:21 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Delay Compensation
Thats right for an audio track. insert one on an aux and see what it reads
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-09-2010, 08:38 AM
Originally Posted by crizdee View Post
Chris
I guess I must be missing something basic. I tried it on a aux track with the same results. Besides, delay is delay. Why would it be different on an audio track than on an aux track?
Old 11-09-2010, 08:55 AM
Brandonx1 Brandonx1 is offline
If you are not using HD than most plug ins have no delay. Try putting an L3 or impulse response reverb on a channel.
Best
GregJ GregJ is offline
Do the AIR plugins induce any delay?
They might be (should be) zero latency. So the Delay counter would read zero in that case.
I'm not 100% sure on this, but that might be why you aren't seeing any delay with them.
Thanks,
GregJ
Old 11-09-2010, 09:01 AM
TOM@METRO's Avatar
Control click the Volume indicator to see what the latency of a plug-in actually is. If there is none, there will be no compensation. Insert Ozone4 and take a look.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-10-2010, 09:04 AM
Thanks. I see what you mean about Ozone, a delay of 1300 samples.
[IMG] code is Off
Delay compensation with backline delay chuck goodwin VENUE Live Sound Systems 3 08-09-2013 07:54 AM
Delay Compensation DasTweaker VENUE Live Sound Systems 4 06-01-2012 12:46 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 08:59 PM
