Old 03-21-2013, 10:50 AM
sweeneyparaic27 sweeneyparaic27 is offline
Default Recording with Macbook Pro
Hi there
Bought the Macbook Pro Brand new at a knock down price but had to buy it there and then with no modifications.
So I need to buy myself a good HD with FW800 and one that spins at 7200 RPM.
Firstly any recommendations on a specific type/model.
Also should I connect my interface to the HD and the HD to my Macbook ?
Interface is a UA Apollo (dont have Thunderbolt card and wont be purchasing for the time being)
Also Im based in Ireland
Thanks for the help
Paraic
Old 03-21-2013, 11:22 AM
leobaker leobaker is offline
Default Re: Recording with Macbook Pro
Hello,
The Glyph drives are good as you can't sue any Firewire drive as their are compatibility with the chipset on the hard drive.
http://www.showmeprotools.com/pro-to...l-hard-drives/
I use the Glyph drive and it runs perfect. I tried Lacie but Pro Tools kept crashing when it was attatched due to the Firewire chipset it used.
Leo
Old 03-21-2013, 11:23 AM
Also, you should connect the audio interface into the harddrive then the harddrive to the computer.
Old 03-21-2013, 01:17 PM
Ditto(more below). Glyph are good but pricey. OWC are my choice for cost vs quality.
Re. the hookup, yes, placing the drive in between the computer and interface is preferred for this reason; if the interface loses connection(by accident or you shut it off) the drive might still be writing data(just because the session is closed, doesn't mean the drive is doing something). If the drive is at the end of the line and the interface loses power, the drive loses connection, and any data being written at that moment can become corrupted and useless. You CAN hook it all up this way and it will work, but you need to be more cautious. Best(in either case) to either eject the drive or do a shutdown of the computer(just to be certain no data is mid-stream)
Old 03-21-2013, 02:08 PM
dr_daw's Avatar
dr_daw dr_daw is offline
+1 on the Glyph drives as well over here. The only downside I find is they are a little noisy. I personally haven't had luck daisy chaining my HD to Saffire Pro 40, but your Apollo may work.
I was forced to use t-bolt to fw-800 adapter for my HD. Hopefully your MBP has 8gb of ram...Good luck regardless.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 03-21-2013, 02:36 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
At home I use G Drives and they are reliable, inexpensive and meet the qualifications for an external drive... I use drive arrays professionally
Glyph was industry standard but I have had older models (I dont buy them anymore) crap out more than any other drive I have used (I have 2 dozen Glyph drives that are bad in a closet waiting to be shredded)... the way I did it for years is to buy 2 Glyph drives and have one act as a clone (backup), saved my ass many times on some big projects.
Also something to consider SSD drives have been approved by Avid to use for for PT.
*Solid State Drives (SSDs) have been tested and are qualified for use with Pro Tools 10, either as system or audio drives.
Read this page for more info:
http://avid.force.com/pkb/articles/e...Drives&x=0&y=0
Old 03-21-2013, 04:06 PM
Oliver M Oliver M is offline
Originally Posted by sweeneyparaic27 View Post
Hi there
I can recommend 7.200 RPM drives like Western Digital Black (not Green!!) or Seagate Barracudas. If you have the right tools I would suggest to buy enclosures from OWC, like the OWC Mercury Elite Pro. You will buy the drives separate from the enclosures.
Another option is Glyph, I have made good experiences with the Glyph GT 051 Tabletops with corresponding 1000 GB Keys, they are pricey though.
Oliver
Old 03-21-2013, 04:44 PM
ericgreedy ericgreedy is offline
Get a data doubler kit from OWC.... take out the super-drive (you can place it in an external enclosure for the rare times you need CD/DVD drive).... then add another 500GB internal drive to record too.. superior to using an external drive. It will leave the firewire buss for the apollo. You can get an additional drive to back-up to.
Old 03-21-2013, 04:46 PM
Yes, in case he wants to mess with his warranty and is safe enough to do all this himself.
Oliver
Old 03-21-2013, 04:48 PM
it's not hard to do. If a mac has an issue it invariable shows up with it. FYI.... buy refurbished Mac's for the best value
Recording from SC48 to MacBook Air Tigerspill VENUE Live Sound Systems 2 04-16-2012 04:31 PM
Anyone using just a plain MacBook for recording? maxxdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-12-2009 06:40 PM
Recording to a Macbook Pro question... Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-07-2009 11:44 PM
Macbook recording on it's desktop Antboogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-04-2009 02:07 PM
Recording to Macintosh HD (Macbook Pro) shtik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 01-31-2009 10:44 PM
