Old 01-14-2013, 07:07 AM
shyam shyam is offline
Default When i Playback my project i cannot change the Volume faders
Hey,
when ever i record i have two problems:
1.) When i record a new track (Audio & MIDI) i cannot seem to control volume faders as when i try to play the song it defaults to the standrard volume setting, is there something like track automation enabled, if so how can i turn this off?
Its really frustrating me, so any help on this would be appriciated
Old 01-14-2013, 10:56 AM
Default Re: When i Playback my project i cannot change the Volume faders
While a track is in record, you should be able to adjust the fader(automation is bypassed for a track in record)but it may snap back when you are out of record. Here are two options: turn OFF automation for that track(the button that defaults to READ). Select volume view(EDIT window) and drag the line up/down. In any case, I recommend hitting youtube.com and searching for things like "using pro tools automation"(without the quotes) so you can dig in and learn(there's a lot to learn on any DAW)
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 02:08 PM
Cannot change internal hard drive to "playback" volume playsguitars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-13-2008 01:50 PM
VCA Faders Not Controlling Volume Tallcat Productions Pro Tools TDM Systems (Mac) 1 12-02-2006 03:44 PM
How do I change a session back to +6dB faders. SilkBasilar Pro Tools TDM Systems (Mac) 5 04-24-2006 07:11 AM
Project mix and Mac 2.5 quad core. Faders do not- jmem360 Pro Tools M-Powered (Mac) 2 02-16-2006 01:19 PM
