Old 09-23-2018, 07:59 PM
DannyB_KY's Avatar
DannyB_KY DannyB_KY is offline
Default How to remove unwanted plugins?
I'm sure this has been asked before, and I apologize for asking again, as me and search ain't gettin' along.
How do I remove unwanted/unlicensed/old plugins from a Mac?
Detailed guidance is mush appreciated!
An understand spouse, some mics, tube guitar amps, gray foam stuff stuck to the walls, a drum kit, a Mac or two, and an interface. A really understanding spouse!
Old 09-23-2018, 08:01 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: How to remove unwanted plugins?
Hi friend !
Here you can find where they are stored . From there just removed the unwanted ones .
http://avid.force.com/pkb/articles/e...older-location
Sent from my SM-G950U using Tapatalk
Mac M1 Studio Ultra - Sequoia Beta OS
Avid Carbon Interface
Protools Ultimate
Old 09-23-2018, 09:25 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Also.
Know that removing ALL AAX plugin's is Fine. Modern Pro Tools will AUTO-Install all base plug-in's fresh. (Additional installs for Extra Plugs may be required)
Pro Tools current 2018
research the rest of your actual-needed plug-ins and get the latest installers for your licenses.
Old 09-23-2018, 09:33 PM
DannyB_KY's Avatar
Originally Posted by jeam25 View Post
Hi friend !
Thank you!
Old 09-24-2018, 05:32 AM
Hi friend !
Be aware that this is just for the aax format plugins. A lot of people when they install a plugin will allow the installer to also install the au/vst/vst3 format plugins as well. They can be found at:
The AU plugin is at location:
/Library/Audio/Plug-Ins/Components
and/or:
Users/your username/Library/Audio/Plug-ins/components
And the VSTs are at locations:
/Library/Audio/Plug-Ins/VST
and or:
Users/your username/Library/Audio/Plug-ins/VST
/Library/Audio/Plug-Ins/VST3
and/or:
Users/your username/Library/Audio/Plug-ins/VST3
Also for the aax format plugins one can move them to the unused plugins folder
Jack
QAPLA!
Old 05-11-2020, 07:48 AM
Popmeise's Avatar
Popmeise Popmeise is offline
"Know that removing ALL AAX plugin's is Fine. Modern Pro Tools will AUTO-Install all base plug-in's fresh. (Additional installs for Extra Plugs may be required)
Pro Tools current 2018"
I can't delete "Eleven Lite aax-plugin" (I have got Eleven, so I don't need Eleven Lite). Every time I start Pro Tools it is there again. Is this the cause?
Pro Tools 12.8.4
Pro Tools 12.5.1
Win 10
Eleven Rack
Asio4All
M-Audio Oxygen 49 mk4
TLM 102
Gibson Classic Rock Marble
AKG K 271 MKII
Old 05-11-2020, 09:37 AM
Pro Tools 12.8.4
Probably: Go to Applications -> Pro Tools: Right click to "Show Package Contents", then navigate to Contents -> Plugins -> Core Plugins. You can remove it if it's in there - then it won't keep auto-installing.
http://www.richbreen.com
Mac Studio / Ventura, PT 2024.6. HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 05-11-2020, 10:02 AM
That's for a Mac - the person asking the question is on Windows.
Jack
QAPLA!
Old 05-11-2020, 10:35 AM
?? OP: "How do I remove unwanted/unlicensed/old plugins from a Mac? "
Old 05-11-2020, 10:52 AM
Southsidemusic's Avatar
True but OP’s post is 2 years old so hopefully he has got that sorted but the other guy Popmeise who asked today is on PC
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Removing unwanted plugins Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-02-2007 09:42 AM
How to remove unwanted bar numbers? jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-24-2006 03:14 PM
unwanted plugins: remove but not uninstall? gravityspull 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-11-2005 08:46 PM
Unwanted Plugins MikeSoloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-05-2004 09:47 PM
15 ways to remove the unwanted noises from records : DORUMALAIA General Discussion 0 06-14-2003 08:20 PM
