#221
Re: Hackintosh - Salvage your HD PCI cards - You Can Do It Too!
Go for it.
Make a backup first! I'm pretty sure I used 4.7.1. I'll check when I boot that Hack. I'm on my MBP at the moment. I've been doing some reading about your MB… Check out this link: http://www.insanelymac.com/forum/top...ection/page-15 There may be something there that will help you as far as kexts, etc… and updating to the ML OSX. Honestly though, if you have PT 10HD3 TDM running on Lion 10.7.3 you're golden. Why do you want to upgrade to ML? Are you planning on running PT11? I struggled with it only for that reason. To see what the differences were. Your TDM system will not benefit from ML. It can't run 64bit. Remember you NEED more RAM. That could be your problem right there. The OS needs 4GB and now that PT is using a RAM based buffer you absolutely need at least 4GB to operate it. I suggest adding 16GB first and foremost. Good luck!!
AQ. Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6 Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9 Black Lion modified OMNI HD w/XB clock Multiple Black Lion modified 192 FM/XB interfaces Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native) |
#222
In terms of Lion vs ML, you're absolutely right. The whole aim of the exercise was to enable me to run PT10 HD & Komplete 9 together on my TDM rig, & Meads has sorted that out for me now, so if I get no further on this journey, then i'm still happy with the result. However, if I *can* get ML running too, I feel it would probably give the whole rig an extra year of life, in terms of future software compatibility, so would still be worth getting to work in the long run. Cheers
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2024.6, HDX , AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2024.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
#223
I went back to my notes and I used Multibeast 5.2.1 for this ML build.
I don't usually run PT11 but I launched it yesterday to make sure it worked and indeed it does. So I can confirm that with my particular build I have PT10HD4 TDM as well as PT11HD (no HDX cards) Native running on this Hack. PT11HD does lower the CPU usage dramatically BUT this is without any plugins. If I launch PT10HD and take all the plugins off the session it's virtually the same. I like the changes I see in PT11 but until there are AAX plugin versions of what I normally use and they LOAD CORRECTLY (this seems to be a well documented problem here on the DUC) I'm staying on PT10HD. I can track and mix in TDM or mix Native with the extra ADC if necessary. Let me know how things work out for you.
#224
Isn't it really all about using the gear that is "truly" ready for prime time?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. Last edited by studiojimi; 11-24-2013 at 07:37 PM. |
#225
Not if you want to see how the other half lives.
#226
the half that's chasing their tail?
no thanks i'd rather make some money today. (and some good music)
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#227
You know studiojimi, this particular thread is about people trying to help each other with their systems.
I'm overjoyed that you have a nice big stable system, you can work and make money doing so. Have a nice day.
#228
i'm NOT interested in your commenting on my comments when perhaps you don't even know where i'm really coming from…let's move along in the discussion and keep the personal comments out of the discussion. let me add something check this cat out www.quocomputer.com RASHANTHA DeSilva i met him at a ProTools Tech breakfast …really liked his pitch
#229
I've spoken to him as well.
His Hacks are not for TDM based systems.
#230
Guys, here is a good website about the subject that helped me a lot.
Unless somebody already have pointed this out along the way, otherwise here is the link: http://rampagedev.wordpress.com/author/rampagedev/
TiPo Pro-Tools 10.3.10 HD 2 Accel PCIe OSX 10.10.3 |
Hackintosh - Salvage your HD PCI cards - You Can Do It Too! | jeremyroberts | macOS | 2 | 07-01-2016 09:32 AM |
Hackintosh on my rig? | Raoul23 | Pro Tools TDM Systems (Win) | 7 | 07-01-2011 03:26 PM |
Hackintosh Help | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-16-2010 10:45 AM |
Get a laptop or salvage old machine?? | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-24-2008 01:28 PM |
OT - Salvage a bad DAT - Possible? | soundsurfr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-08-2003 12:55 AM |
