Hi All, I am about to get a new Mac Pro and have a HD5 Accel PCI, can anyone confirm there is NO latency etc with this chassis? I know the Mac will see it as all PCIe, is it near enough exactly the same as having it all inside the box?
Also because Pro Tools sees the cards as inside the box due to PCIe should I be safe with the HD5 and Chassis for future PT HD updates (I am sure they are going to dump standard PCI very soon) thanks in advance for help
HD 3 Accel PCI HP XW9300 192 I/O Midi I/O |
Haven't had a chance to really push my system to the max track count since getting my Mac Pro, but I am running an HD5 with the same Magma chassis and have had zero issue (knock woodx1000
I have an HD3 Accel, but I regularly push over 80-tracks live through a Venue console into PTHD for live TV----and mix over 120-tracks with NO issues, hangups, lockups, anything. You're fine....
works great with macpro 8core.. hd 5..
www.garyvandy.com |
No problems at all with the chassis, a Mac Pro 8 Core and HD 6 here either.
All good for me. HD3 in a PE6R4, Mac Pro 8-core 2.28.
Brian Steckler, Producer Mac Studio Ultra M1 (128GB) Sequoia 15.3.1 Avid Carbon PT Ultimate 24.10.1.204 Current as of 5/3/25 |
All good - see my signature for my setup below.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate |
...0 latency / 0 problems - a little pricey but well worth not having a single problem, it runs as if the cards were in the Mac Pro itself. I'm running a fully loaded HD 6 system.
works great with macpro 8core.. HD7!!
The lowest buffer setting I can do with mine is 64 samples.
I would not consider that a lot of latency. A lot of people get confused with high latency with expansions chassis was do to old slow "Digidesign Expansion Chassis HD" none of the Magma chassis had those problems of the Digi Exp HD |
Magma PE6R4-I or PE6R4 EM | Iker | Pro Tools TDM Systems (Mac) | 16 | 10-07-2016 02:27 AM |
PT8.1 with Magma PE6R4-I | mattbell1978 | Pro Tools TDM Systems (Win) | 0 | 03-18-2014 07:19 AM |
Magma PE6R4 | subwoof | Post - Surround - Video | 4 | 03-21-2010 02:18 PM |
Anyone using the Magma PE6R4 with a G5? | mixboy bob | Pro Tools TDM Systems (Mac) | 4 | 06-11-2009 08:29 AM |
Magma PE6R4 | TimNielsen | Pro Tools TDM Systems (Mac) | 13 | 11-19-2008 09:40 PM |
