Old 11-09-2009, 01:24 PM
Ssaidvox1 Ssaidvox1 is offline
Question Pro Tools 8.0.1 adding space on file exports and bounces?
Hi all,
I am trying to export a specific region length of some songs I composed for a video game. It is imperative that these loop perfectly. I noticed that when bouncing, I have some extra space at the head and tail in the final final that I have bounced from my session.
To fix the problem, I thought an export might eliminate the extra 100 - 200ms of silence the bounce was adding, so I imported the bounces into a new session, cut the length, and exported my masters. Unfortunately, the export added space as well. Has anyone come up for a workaround for this?
This causes a lot of complications with sync when composing for video, as frame 1 no longer = frame 1 in the audio file.
Thanks in advance for reading!!
Mark Abrams
tel: 419.610.8107
email: mabramsaudio@gmail.com
url: www.markabramsaudio.com
Old 11-09-2009, 02:15 PM
DigiTechSupt's Avatar
Default Re: Pro Tools 8.0.1 adding space on file exports and bounces?
What format are you bouncing to?
If you import the file back into Pro Tools, does it show the exact same length file as the original bounce area?
Avid Audio Tech Support
Support FAQ
Old 11-09-2009, 02:25 PM
Ale Ale is offline
I do not know whats the reason but maybe you should consider to record your master to a new track.
This ist the only way with absolutely no problems.
And you can punch into your masters.
Ale
PT HD Ultimate 2020.11 6/12-Core Westmere/ 48 GB / OS 10.13.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2020.11 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002
Old 02-04-2010, 09:48 AM
LT_CJ LT_CJ is offline
Has anyone come up with a reason why this is happening and a fix? We are having the same problem.
Two Macs, one Dual 2GhzPPC, one Intel iMac , both running 8.0.3 and regular Leopard.
"If you import the file back into Pro Tools, does it show the exact same length file as the original bounce area?"
No, there is space at the head. Exporting to WAV. Tried 24/48 and 16/44 AIFFS too, same deal.
So if I bounce a loop (that loops perfectly in loop-play in PT) down to a WAV, then import it into a new PT session, there's .058 seconds of space at the head of the file. Even trimming that space to the exact start of the waveform does not result in a loopable file. So importing, trimming and Exporting Region to File will not work.
Thanks.
Old 02-16-2010, 03:02 PM
ebk ebk is offline
Exclamation Re: Pro Tools 8.0.1 adding space on file exports and bounces?
hello there, i do have the exact same problem:
i need to bounce perfect loops created in protools. the result is always around 23 milliseconds "silence" in the beginning of the file. but it is like shifting the audio for that milliseconds, so some is cut in the end. this is why simply cutting the beginning in an other program doesnt create the loop (and this cant be the solution for that anyways).
before you reply with the usual, i tried out anything i know and what i could google:
- i bounced different files (wav, aiff)
- i deleted effects to avoid delays on that side. i even tried out different combinations of the effects.
- i bounced in resolutions of 24 bit and 16 bit (all with the standart cd 44.1 khz)
- i tried track recording instead of bouncing
- i set the "pre-roll" to 0 and deactivated it
- i tried mono and stereo
any of these try outs result in the same litte silence in beginning of the render.
i must do something wrong ! dont i ?
i cant understand and dont want to believe that the whole world of pro tools didnt recognize this problem or simply ignores it.
please, please help ! anyone : )
thank you
here is what i want to do:
- i have a beat created out of 8 different instruments. i need every instrument in a seperate loop. some 2 bars some 1 bar. the track s 103 bpm
- i select the 1 or 2 bars and bounce the region
- recordings are done in 24 bit standart 44.1 khz
- protools LE (mbox 2) version 8.0.1
- win xp computer pretty fast with decent ram (around 8 months old)
- the system is for sound processing only and is working fine with no other problems crashes whatso ever...
ps: my work around for now will be: bouncing out 6 bars (or 3 bars) so the middle will be the full, perfect loop. cutting this in audacity freeware. but i dont like that at all, there must be a correct way out of protools...
>>> this thread here inspired my of a work around i describe there as well, maybe this helps... : http://duc.digidesign.com/showthread...74#post1556074
Old 04-06-2010, 12:06 PM
I decided to post an update in EBK's thread too: http://duc.digidesign.com/showthread.php?p=1556074
As we know, one of the issues is: when importing a bounced track back into a PT session, there is added space at the head, and even removing that dead space does not create a loop that works properly.
I tried bringing in a bounced track (with dead space) into the original session, chopping off the dead space and playing it along with my original tracks. It matched up perfectly until the very end. That led me to believe some audio information was getting cut off at the end due to the added space at the head, so I tried this:
1. I bounced my track as usual, with all plug-ins (Xpand2, Maxim, Ozone3, among others). However - instead of just bouncing the 64 bars, I added 1 bar at the end, so my bounce would be a total of 65 bars (of course if I tried to play that bounce as a loop, it wouldn't work).
2. I imported my bounce back into a PT session (in this case, the same one, b/c I was just testing it out), removed the dead space at the beginning, moved the file to the start of the session (Measure 1/1), then went to the end of the 64th bar (the start of Measure 65/1) and cropped the end. Now I have a loop that is exactly 64 bars.
3. Played it back and it sounded perfect. So I then highlighted that edited loop, went to the Region bin and Exported Region as File.
4. To double-check, I imported that Exported Region/File back into the session and lo and behold, I've got a piece of music that loops perfectly.
My one caveat about this is that the file I'm trying this out with purposely sounds kind of old and crappy (it's a saloon piano), so I'm anxious to try it out with something different.
Thanks to EBK and everyone else for all your help. This has been awesome!
Old 07-08-2010, 04:00 AM
zentom zentom is offline
Hi!
I got it fixed by changing the compensation engine mode.
see here for details.
http://duc.digidesign.com/showpost.p...2&postcount=25
Help!!! My Bounces Longer than actual session file! josholds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2008 08:57 PM
Bounces BUT NO FILE is created psklpt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-24-2007 04:38 AM
MP3 file bounces... then mysteriously disappears! tdellaringa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-06-2006 05:28 AM
cannot play the .wav file Pro Tools exports joo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-24-2005 05:40 AM
MP3 File Bounces obee Tips & Tricks 2 10-06-2003 09:18 AM
