Old 08-19-2013, 09:47 PM
Sparky1 Sparky1 is offline
Default Midi Export -> "Apply Real Time Properties" Question
Hi there.
I am trying to understand the significance of selecting "Apply Real Time Properties" when exporting a midi file.
Do I need to select this when exporting a midi?
What value does it add to the final performance of the midi file?
When I export a midi with this selected - it seems that the "midi mix" is different that the original "midi mix" within PT 10
Thanks for any help in understanding this...
Sparky
Old 08-21-2013, 09:25 PM
Default Re: Midi Export -> "Apply Real Time Properties" Question
Bump...
Sparky
Old 12-12-2020, 05:54 AM
Luigi82's Avatar
Luigi82 Luigi82 is offline
In a MIDI Editor window, right click and you see the MIDI Real-Time option (Chapter 31 in my PT reference guide).
If you make active one of those, it applies when playbacking your session (as a playback option it doesn't apply to your MIDI edition, unless you press "write to track").
If you export your MIDI file selecting "Apply Real-Time Properties" it will write these options in you exported midi file (that's why it sounds different than what you see "painted" in your MIDI track).
Let me know
AMD Ryzen 5 3600 3.6 GHz + 32 GB RAM
Windows 10 (64 bits)
MBOX 2 PRO + Pro Tools 10
midi real time properties issues End Over End Windows 0 03-14-2014 12:38 PM
Question about midi real-time properties mahag macOS 2 05-05-2013 12:54 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 04:04 PM
Problem with real time MIDI properties Ray Lyon Pro Tools TDM Systems (Mac) 0 10-30-2006 06:54 PM
Soft Synth That Works "Real Time" w/XP & TDM? Dave Lang Pro Tools TDM Systems (Win) 1 04-03-2003 03:42 PM
