Old 10-11-2008, 01:22 PM
Akkatha Akkatha is offline
Unhappy Extensive 9092 errors after upgrading system.
First things first, hello to all! I've been reading these forums for hours trying to sort out my issues to no avail.... hopefully you wont mind if i try to pick some of your brains on this!
I used to run a P4 hyperthreading processor on XP SP2 on a Dell motherboard, unfortunately I have no idea which chipset it ran . Aside from the chip and the mobo I have not changed a thing in my upgrades.
I ordered the Intel 'Bearlake' Q6600 quad core processor as I'd seen and heard great reviews for performance and the price was right for me. The new motherboard was bought to match the processor, it's an ASUS P5K PRO model running the Intel P31/P35 chipset. After the install a fresh format was made on a new Maxtor 160Gb HD and XP SP2 installed which was then updated to SP3.
If a PC Wizard System scan would help please let me know and I'll post one up ASAP.
After installing PT LE 7.4 I began encountering problems. I use an MBox 2 Pro connected by firewire. I'm not 100% sure of the details on the Firewire card I'm using, but it's exactly the same as the one used in the previous build where PT worked perfectly. Besides, these problems occur whether I connect the Mbox to the PCI firewire card or the Firewire ports on the case connected direct to the mobo.
I am constantly getting 9092 'The OS held off interrupts for too long, try increasing the hardware buffer size in the playback engine' messages. These occur whenever I try to play or record anything at all, even a single mono audio track. In essence, PT is completely unusable.
The Mbox works fine as an interface for Cubase SX3, however I bought it to use PT obviously so I'd like to get a fix
In reading these posts and the support forum I have tried a few things, all have had no effect at all -
- Disabling all speedstepping on the processor.
- Using task manager to make pro tools run on a single core using the 'affinity' menu. No combination of any of the four cores helps at all.
- Changing and experimenting with every option in the playback engine. No matter what buffer size, CPU threshold or amount of cores I have selected I still get the same 9092 message every time i try to do anything.
Finally, I tried installing the dual core hotfix from Microsoft. However, as SP3 has been installed the hotfix said it didn't need to be applied.
If anyone has any suggestions or answers to this problem I would greatly appreciate it! I'm trying to finish my degree and PT is pretty essential to a few of the modules.
Thanks in advance and apologies for making my first post a long and boring one, I promise to be a bit more upbeat next time!
Old 10-11-2008, 03:34 PM
Default Re: Extensive 9092 errors after upgrading system.
Update the PACE drivers as well. Then maybe see if you need updated drivers for any of your other things like video card or even the firewire card Fresh drivers are usually a good idea any time. What drive are you recording to? If its an internal drive, is it formatted as BASIC? Maybe double-check all the usual setup tweaks as well.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 10-12-2008, 05:24 AM
Thanks for the response Albee
I've updated the PACE drivers, although I don't use an iLock it was worth a try! I've also updated every other driver relating to PT I could find including firewire and the Mbox2 Pro but it still wont play ball.
I found another thread saying occasionally PCi express cards can cause latency spikes with a link to a program called DPC latency. I downloaded that and checked all my drives.... theres not a single latency bar above the green level. Highest i got was around 400ms.
To try and avoid the graphics card issues I uninstalled all my graphics drivers and rebooted the PC. Pro Tools still gives me a 9092 whenever I try to playback or record anything.
I've also reformatted my Audio drive but to no avail.
The frustrating thing is that it worked on my old P4 chip, and I bought the Q6600 to try and get a bit more 'oomph' out of PT
Old 10-12-2008, 09:08 AM
Quick update, Have also tried using an old ATI GPU card, to no effect.
To test things out I put my old system back together, only differences being the Q6600 and the ASUS P5K PRO motherboard. PT worked like a charm. Not really too happy about having a quad core and a nice mobo lying around doing nothing though :S
Is anybody else using the same mobo at all? Or something close perhaps? Your input would be greatly appreciated!
Old 10-12-2008, 09:19 AM
netnoggin netnoggin is offline
A good place to look would be shared interrupts. Make sure your firewire device is not sharing an interrupt with anything else. In my case, the default config was sharing with the ethernet controller and raising heck. Luckily my Asus had two ethernet ports so I disabled the one I was on and used the other. Cleared it right up.
This would especially fit on a new build. It's very likely to be different than your old board, thus the reason why things worked fine on the old one.
Old 10-12-2008, 10:19 AM
Ahh sounds like a good thing to look at netnoggin!
Sorry to ask/sound like a nub.... but any chance you could pop a quick post up of how to check if they are sharing an interrupt?
Theres 2 F/w, 1 ethernet connector which is unused as I have a wireless card installed and 7 USB ports all connected to the mobo.
I can pop parts together and fiddle around with stuff, but I've never had to delve this far in for one program... PT is a fickle and picky beast!
Thanks again all!
Old 10-12-2008, 12:31 PM
The Weed's Avatar
The Weed The Weed is offline
PACE drivers have nothing to do with an iLok, they're part of the piracy protection in Pro Tools. Yes iLoks are for the same thing, but different driver and process.
You may want to try disabling that wireless card, they can cause issues with PT. See the General Troubleshooting thread and maybe, after trying everything there, like after upgrading anything to do with PT, trashing your Preferences and Databases and rebooting, you could post a Sandra or PC Wizard report if you're still having problems.
Cheers,
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 10-13-2008, 07:05 AM
Thanks again for all your help guys, I'm afraid I'm still having problems.
I've tried all the tweaking tips, been through my devices one by one and still no improvement. The strange thing is that if I set the Mbox2 Pro as my primary driver for windows I can play music through itunes, movies etc through vlc and pretty much any streaming content on the internet with no audio problems at all.
However, using any program that uses real time audio such as amplitube, cubase SX3 etc gives pops and clicks that are unbearable and impossible to work with. I'm still getting 9092 errors everytime I do anything in protools too
The firewire onboard my motherboard is VIA OCHI, as is the PCI firewire card I have installed. I'm looking at ordering a Texas Instruments chipset card, but I first need to determine whether that would fix the problem or whether its another piece of hardware. The likely suspect would be the motherboard. I've used the VIA PCI card on my previous build with no problems, but I'm aware that different hardware interacts completely differently. I've found that my firewire interface shares IRQ's with several other components. A mainboard and a buses and drivers SANDRA report is posted up in the nest two posts.
I've never played around with IRQ's before so if anyone sees anything that could be causing problems I'd love to know!
Thank you all for you time so far, its very much appreciated!
Old 10-13-2008, 07:06 AM
SANDRA mainboard report.
SiSoftware Sandra
System
Manufacturer : System manufacturer
Model : P5K PRO
Family : To Be Filled By O.E.M.
Version : System Version
Serial Number : System Serial Number
SKU Number : To Be Filled By O.E.M.
System Chassis
Manufacturer : Chassis Manufacture
Type : Desktop
Can be locked : No
Version : Chassis Version
Power Cord(s) : 1
Serial Number : Chassis Serial Number
Asset Tag : Asset-1234567890
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : ASUSTeK Computer INC.
Multi-Processor (MP) Support : No
MPS Version : 1.40
Model : P5K PRO
Type : Mainboard
Version : Rev 1.xx
Serial Number : MS1C85B11002342
Asset Tag : To Be Filled By O.E.M.
Location in Chassis : To Be Filled By O.E.M.
System BIOS : 64-1202-000001-00101111-072208-Bearlake
System Mainboard Properties
Removable : No
Replaceable : Yes
Hot Swap : No
On-board Devices
Onboard Ethernet : Ethernet Adapter (Enabled)
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 2GB
BANK0 - DIMM0 : Manufacturer0 PartNum0 SerNum0 AssetTagNum0 DIMM Synchronous DDR2 1GB/64 @ 667MHz
BANK1 - DIMM1 : Empty
BANK2 - DIMM2 : Manufacturer2 PartNum2 SerNum2 AssetTagNum2 DIMM Synchronous DDR2 1GB/64 @ 667MHz
BANK3 - DIMM3 : Empty
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Revision : A3
Bus : Intel AGTL+
Independent FSB Channels : 1
Front Side Bus Speed : 4x 267MHz (1.07GHz)
Maximum FSB Speed : 4x 400MHz (1.60GHz)
Width : 64-bit
Crossfire Technology : Yes
I/O Queue Depth : 12 request(s)
Maximum Bus Bandwidth : 8.34GB/s
Features
TXT - Trust Execution Technology : Yes
ME - Management Engine : Yes
AMT - Active Management Technology : Yes
VT-d - Virtualisation Technology : Yes
EF - EastFork Technology : Yes
AP - Agent Presence : Yes
CB - Circuit Breaker : Yes
Auto Fan Speed Control : Yes
Chipset 1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
Number of Ports : 4
In/Out Width : 4-bit / 4-bit
Multiplier : 3/1x
Speed : 1x 100MHz (100MHz)
Logical/Chipset Memory Banks
Bank 0 : 512MB DIMM DDR2 5-5-5-15 3-20-6-4 2T
Bank 1 : 512MB DIMM DDR2 5-5-5-15 3-20-6-4 2T
Bank 4 : 512MB DIMM DDR2 5-5-5-15 3-20-6-4 2T
Bank 5 : 512MB DIMM DDR2 5-5-5-15 3-20-6-4 2T
Maximum Installable Memory : 8GB
Supported Memory Types : ECC DIMM DDR2 DDR3
Channels : 2
Memory Bus Speed : 2x 334MHz (668MHz)
Maximum Memory Speed : 2x 800MHz (1.60GHz)
Multiplier : 5/4x
Width : 64-bit
Memory Controller in Processor : No
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
Maximum Memory Bus Bandwidth : 10.44GB/s
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module
Manufacturer : Corsair
Model : CM2X1024-5400C4
Type : 1GB DIMM DDR2
Technology : 16x(64Mx8)
Speed : PC2-5300U DDR2-666
Standard Timings : 5.0-5-5-15 3-18-5-3
Version : 1.02
Memory DC Line : 1.80V
Set Timing @ 333MHz : 5.0-5-5-15 3-18-5-3
Set Timing @ 267MHz : 4.0-4-4-12 2-15-4-2
Memory Module
Version : 1.02
Environment Monitor 1
Model : Winbond W83627DHG-A ISA
Version : 12.01
Mainboard Specific Support : No
Environment Monitor 2
Model : Intel Core CPU [P1, C4, M0]
Version : 15.11
Temperature Sensor(s)
Board Temperature : 34.00°C
CPU Temperature : 59.00°C td
Auxiliary Temperature : 16.50°C
Cooling Device(s)
CPU Fan : 1383rpm
Voltage Sensor(s)
CPU DC Line : 1.31V
Aux DC Line : 3.30V
+3.3V DC Line : 3.30V
+5V DC Line : 4.46V
+12V DC Line : 11.16V
Standby DC Line : 3.30V
Battery DC Line : 3.08V
System Bus(es) on Hub 1
Version : 2.30
System Bus 0 : PCI
System Bus 1 : PCIe 1.00 x16 2.5Gbps
System Bus 2 : PCIe 1.00 x1 2.5Gbps
System Bus 3 : PCIe 1.00 x1 2.5Gbps
System Bus 4 : PCIe 1.00 x4 2.5Gbps
System Bus 5 : PCI66
LPC Hub Controller 1
Model : ASUS (ICH9) LPC Interface Controller
Revision : A3
ACPI Power Management Enabled : Yes
Advanced TCO Mode Support : Yes
Advanced TCO Mode Enabled : No
High Precision Timer Enabled : Yes
Number of Precision Timers : 4
System Timer : 14.32MHz
Delayed Transaction Enabled : Yes
Disk Controller
Model : ASUS (ICH9) 4 port Serial ATA Storage Controller 1
Interface : SATA
Revision : A3
Maximum SATA Mode : G2 / SATA300
RAID Support : Yes
RAID Enabled : No
Channels : 4
In Use Channels : 3
Port : G1 / SATA150
Port : G1 / SATA150
Port : G1 / SATA150
Disk Controller
Model : ASUS (ICH9) 2 port Serial ATA Storage Controller 2
Interface : SATA
Revision : A3
RAID Support : Yes
RAID Enabled : No
Channels : 2
Disk Controller
Model : ASUS 6101 SATA2 Controller
Interface : ATA
Revision : L3
Channels : 4
Audio Device
Model : ASUS (ICH9) HD Audio Controller
Revision : A3
Type : HD (High-Definition) Audio
Version : 1.00
Number of In / Out / Bi-Directional Streams : 4 / 4 / 0
Number of Serial Data Streams : 1
Audio Codec
Model : Realtek Semiconductor 883 High Definition Audio
Revision : A3
Version : 1.00
Audio Channels : 12
USB Controller 1
Model : ASUS (ICH9) USB Universal Host Controller
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Model : ASUS (ICH9) USB2 Enhanced Host Controller
Revision : A3
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 6
Companion Controllers : 3
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
USB Controller 5
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 6
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 7
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 8
Revision : A3
Version : 2.00
Interface : EHCI
Channels : 6
FireWire/1394 Controller 1
Model : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
Revision : M1
Version : 1.10
Interface : OHCI
Enhanced Support : No
Speed : 400MHz
System SMBus Controller 1
Model : Intel 801xx/63xx SMBus
Version : 0.02
Specification : 2.00
Advanced TCO Mode Enabled : Yes
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
PCIEX16_1 (1h) : PCIe 32-bit +3.3V Shared PME Half-Length Available
PCIEX1_1 (2h) : PCI-X 32-bit +3.3V Shared PME Half-Length Used
PCIEX1_2 (3h) : PCI-X 32-bit +3.3V Shared PME Half-Length Available
PCI_1 (1h) : PCI 32-bit +3.3V Shared PME Half-Length Available
PCI_2 (2h) : PCI 32-bit +3.3V Shared PME Half-Length Used
PCIEX16_2 (4h) : PCIe 32-bit +3.3V Shared PME Half-Length Available
Port Connector(s)
PS/2 Mouse - PS/2 Mouse : Keyboard / PS/2
PS/2 Keyboard - PS/2 Keyboard : Keyboard / PS/2
USB1_2 - USB1_2 : USB / USB
USB3_4 - USB3_4 : USB / USB
GbE LAN - GbE LAN : Network / RJ-45
AUDIO - AUDIO : Audio
COM 1 - COM 1 : Serial Port 16550A / DB-9 pin male
Audio Line Out1 - Audio Line Out1 : Audio / Mini-jack
Audio Line Out2 - Audio Line Out2 : Audio / Mini-jack
Audio Line Out3 - Audio Line Out3 : Audio / Mini-jack
Audio Line Out4 - Audio Line Out4 : Audio / Mini-jack
Audio Line Out5 - Audio Line Out5 : Audio / Mini-jack
Audio Line Out6 - Audio Line Out6 : Audio / Mini-jack
SPDIF_OUT - SPDIF_OUT : Audio / CD-ROM Sound Input
IE1394_1 - FireWire 1 : FireWire/1394
IE1394_2 - FireWire 2 : FireWire/1394
SATA1 : SATA
SATA2 : SATA
SATA3 : SATA
SATA4 : SATA
SATA5 : SATA
SATA6 : SATA
PRI_EIDE : SATA
USB5_6 : USB / USB
USB7_8 : USB / USB
USB9_10 : USB / USB
USB11_12 : USB / USB
FLOPPY : Floppy Disk
CD : Audio / CD-ROM Sound Input
AAFP : Audio / Mini-jack
FP_AUDIO : Audio / CD-ROM Sound Input
CPU_FAN : None
PWR_FAN : None
CHA_FAN1 : None
CHA_FAN2 : None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 10-13-2008, 07:33 AM
The version of SANDRA I have wont let me view IRQ assignments, so here they are as presented in my device manager.
(ISA) 0 System Timer
(ISA) 1 Standard 101/102 key or Microsoft Natural PS/2 Keyboard
(ISA) 4 Communications Port (COM 1)
(ISA) 6 Standard Floppy Disk controller
(ISA) 8 System CMOS/Real time clock
(ISA) 9 AOGUWRT5 IDE Controller
(ISA) 9 Microsoft ACPI-Compliant system
(ISA) 12 Microsoft PS/2 Mouse
(ISA) 13 Numeric Data Processor
(PCI) 5 Intel ICH9 Family SM bus Controller - 2930
(PCI) 16 Intel G33/G31/P35 Express Chipset PCI Express root port - 29C1
(PCI) 16 Intel ICH9 family PCI express root port 6 - 294A
(PCI) 16 Intel ICH9 family USB universal host controller - 2937
(PCI) 16 Nvidia Geforce 7600 GT
(PCI) 16 Standard dual channel PCI IDE controller
(PCI) 16 VIA OHCI Compliant IEEE 1394 Host controller
(PCI) 17 Intel ICH9 Family PCI Express root port 1 - 2940
(PCI) 17 Intel ICH9 Family PCI Express root port 5 - 2948
(PCI) 17 Mavell Yukon 88E8056 PCI-E gigabit ethernet controller
(PCI) 18 Intel ICH9 family USB universal host controller - 2939
(PCI) 18 Intel ICH9 family USB universal host controller - 2936
(PCI) 18 Intel ICH9 family USB universal host controller - 293C
(PCI) 18 WA-T2(3) (hash*)2
(PCI) 19 Intel ICH9 family USB universal host controller - 2935
(PCI) 21 Intel ICH9 family USB universal host controller - 2938
(PCI) 22 Intel ICH9 2 port serial ATA storage controller 2 - 2926
(PCI) 22 Intel ICH9 4 port serial ATA storage controller 2 - 2920
(PCI) 22 Microsoft UAA bus driver for high definition audio
(PCI) 23 Intel ICH9 family USB universal host controller - 2934
(PCI) 23 Intel ICH9 family USB universal host controller - 293A
Crippling 9092 errors with hd native! please help sam_silent Pro Tools HDX & HD Native Systems (Mac) 21 12-16-2012 05:02 PM
Windows 7 x64 9092 errors SRA893 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-18-2010 09:13 PM
9092 Errors... Upgrading to better RAM? mosdefin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-13-2010 12:15 PM
9092 and 9092 Errors in Pro Tools LE MBOX 2 HELP ME PLEASE oball25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-19-2008 03:21 AM
9092 Buffer Errors BeeWee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-08-2005 08:55 PM
