Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 09-06-2021, 05:55 AM
Lou Ruiz Lou Ruiz is offline
Default Phantom Power MboxPro3
Hi, is there any way to harm another mic through the front panel entrance (mic) when activating the phantom Power ?
When doing recordings away from home without using outboard gear I plug in to the Mbox a condenser mic and a Ribbon one.
Not sure if the ribbon is receiving the 48 v as well.
Gracias.
Leo
Old 09-06-2021, 06:31 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Phantom Power MboxPro3
As far as I can remember, the phantom is global for all inputs, not discreete on a channel by channel basis. Which means if you hit it you will fry your ribbon.
Janne
Old 09-06-2021, 09:13 AM
EGS's Avatar
EGS EGS is offline
This? https://www.bhphotovideo.com/c/produ...saAgiiEALw_wcB
Click for audio/video demo
Click for resume
Old 09-07-2021, 02:12 AM
Originally Posted by EGS View Post
Thanks, something like that I was thinking as well...
Old 09-07-2021, 02:22 AM
I´ve been lucky then. The royer managed the voltage for a while.
The Specs allows to deal with the voltage but they suggest to avoid it as much as possible.
Old 09-07-2021, 07:39 AM
Most modern ribbon mics have a transformer in them and transformers will not pass phantom power. The Phantom Blocker in the link looks like a cool idea(and I'm certain it has a 1:1 transformer inside). FWIW, I hit my Cascade Fathead II ribbon mics with phantom many times with no issues.
Old 09-07-2021, 08:04 AM
JFreak's Avatar
Yes, modern ribbons such as Royer 121 has protection. But vintage ribbons will fry.
Janne
Old 09-07-2021, 08:07 AM
Good to know. I´ve done a litle research and apparently problems with modern ribbons comes along with pacthbays. Swiching on and off in the panel can cause troubles to the ribbon mic if conected to phantom.
in fact I was connecting the phantom power first and then the cable to the mic and it is safer to do it the other way around.
Old 09-07-2021, 08:11 AM
JFreak's Avatar
There is also a practically free solution to the phantom power problem. As we all (?) know phantom power is fed between XLR pins 1 and 2, so if you make a custom cable that connects to your ribbon mic with pins 1 and 3 you are safe from phantom power and only downside is you are 180 degrees out of phase (which can be corrected later if necessary). No extra hardware needed, but no balanced connection either.
Janne
Old 09-07-2021, 08:19 AM
I see what you mean. It´s clever. For this kind of improvised and quick sessions can be an effective solution. Cool...
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
Phantom power optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-10-2003 09:19 PM
New to Phantom Power Derek S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-04-2001 08:14 AM
