Structure LE and Structure Full Question
I just got the PTIEP.
I have sessions with Structure LE on them. Can Structure Full and Structure LE coexist within Pro Tools Or Do I have to uninstall Structure LE? Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Re: Structure LE and Structure Full Question
Good question, I'm assuming that when installing Creative Collection ( Structure Free) a dialog stating a higher edition of Structure already exists. In other words, Structure would replace Structure LE. That a side, Structure LE Plug-In settings and Patch will open with Structure.
Aaron Mulqueen - 001 HD Native |
There's no reason to have both because full Structure does everything LE can. In the same way that Xpand2 replaces its predecessor.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
But... The reason I ask is because I have personal unfinished pieces of music using Structure LE. In these sessions Structure LE is set up and tweaked specifically for that song in its session. To go through every session and recreate the settings that I used in Structure LE would a serious undertaking. Is this making sense to anyone?
Full blown Structure should load your settings exact. Structure LE would not be able to load all of the parameters of the full blown version. You should be fine.
I just do not think trust AVID and Structure Full to that intelligent. If someone can confirm the above that would be swell. But until then Russ gave me a viable workaround. Quote:
Of course, it never hurts to be prepared, but plugins get updated all the time and I've never lost anything due to it. Session specific plugin settings are always retained with sessions, not the plugin itself.
Structure Full showing as Structure le | Dj-Ike | Virtual Instruments | 8 | 04-15-2010 03:09 PM |
Structure Full: Modulation matrix modifiers question | systemexclusive | Virtual Instruments | 0 | 02-21-2010 10:36 AM |
can't open Structure LE in Structure Full version | walter rohrbach | Virtual Instruments | 7 | 08-10-2009 03:02 PM |
Structure Full Database View Question | David Penick | Virtual Instruments | 2 | 01-30-2009 07:35 PM |
Structure Full Featured midi enable question | LeeE | Virtual Instruments | 6 | 03-10-2008 06:07 PM |
