Increase & reduce H/W buffer size errors
Does anyone know what to do when you use amplitube and keep getting an error message telling you to increase the h/w buffer size, and then once you do that and resume what you were doing, you get ANOTHER error message telling you to decrease the h/w buffer size??? And so on and so forth.
Thanks, Nikki |
Re: Increase & reduce H/W buffer size errors
Nikki, out of curiosity are you using reason in these sessions that are giving you trouble with amplitube?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
I'm not Nikki, but I have the same problem that she has.
And yes, I am using Reason in these sessions typically. Why, what do you know??? |
Hi Nikki,
Check out this answerbase article and see if it applies to your situation: Click Here Regards, Digidesign Technical Support |
hey Tim, i have problems with amplitube when i'm running a malstrom in reason. only workaround i found was to just record malstrom track( thats if you are using a malstrom) to a new audio track in protools, then get rid of the malstrom in your reason rack. you might want to make a copy of your reason session before you start removing reason devices . close both programs and reopen. open the new song without the malstrom . This is what i did with my reason amplitube problem
I'm not using reason in those particular sessions.
The only workaround I have found so far is to decrease the buffer size to level 2 (the default level). |
Thanks for the tip. Actually, all my IDE channels are already configured in accordance with that particular answerbase article.
Quad 2.5 G5, 4.5G RAM |
If you are running anything less than an AMD 64 3200+ , then I usually recommend upgrading. Especially if you are using a P4 processor. Makes a world of difference. Allen |
I'm having the same issue. I'm a new user running a AMD Sempron 2400+ Do I need to upgrade?
H/W Buffer Size - reduce - increase?? cant win | bigstribs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-20-2010 04:50 AM |
6.8.1 increase/reduce h/w buffer size | rudysg1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-10-2007 12:28 PM |
increase or reduce h/w buffer size | paquito | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 08-23-2007 01:48 AM |
Getting a lot of "-9129 reduce buffer size errors" | woodstiff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-04-2007 10:56 AM |
Reduce/Increase HW/Buffer Size Problem :( | Simon_Night | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-12-2004 04:29 AM |
