EQ on PROTOOLS i sound muffled
i am in desperate need of help with this EQ. i have no idea what to do with it. my voice comes out somewhat muffled and people suggested i use the EQ. may someone please give me a few tips or help me with this.
if u have AIM mine is : SpecificMusician if not just reply here. i thank you in advance. |
Re: EQ on PROTOOLS i sound muffled
What EQ are you using? That's REALLY important.
Adding 12kHz-20kHz a bit can add Air to the audio. Try this: Put the gain of one band of Parametric EQ all the way up and set the Q in the middle. Try moving the Frequency around until you get the un-muffled sound you want and lower the gain and change the Q to fine tune the sound.
If you want to know where the booze is, ask the engineer... |
Well, it is hard to say exactly what freq you need to add or carve.
But for starters; If your voice sounds muddy try two things. 1. cut a little at or near 200Hz. 2. boost at or near 2.5kHz to 3.5kHz (narrow q)find the sweet spot(presence) You can add air 15kHz+ Add fullness around 120Hz Eliminate honky between 300Hz to 900Hz. DeEss as needed. These are just starting points. Find the sweet spot and bring it out. HTH |
thank you i appreciate both replies.. already got me on the right track
Try some compression before the EQ too - that can help add presence and sparkle, especially if its BEFORE the EQ, so any extra muddiness cwill go away.
Try Rennaisance compressor: ratio = 2:1 with maximum gain reduction around -3db to start. If that's too much try lowering the ratio closer to 1.5:1 while still aboserving -2db of gain reduction. |
Step away from the microphone. Seriously. Move back a bit. A lot of boominess is added as you get closer to the Microphone (proximity effect). Your choice of Microphones could be an issue as well.
Mark Reis Sound Designer |
Clear sound through headphone muffled through monitors | wrigglyroger | Windows | 11 | 08-28-2012 01:39 PM |
Output to amp: Muffled Sound? | Karl Houseknecht | Eleven Rack | 16 | 05-17-2011 05:47 PM |
Muffled playback | pumpkinheady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-14-2006 06:11 PM |
Mix sounds muffled | toadiesXJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-22-2002 02:52 AM |
Help, Muffled Sound in HD system | doug_hti | Pro Tools TDM Systems (Mac) | 20 | 06-20-2002 12:03 AM |
