I´m running Reason via Rewire to PT LE 6.1.1. It works great, except that the midi doesn´t seem to record the footwork I do with the sustain pedal. I can adjust the sustain afterwards in PT, but that is something you do not wan´t to do.
Any idea´s on what may be the problem? I have tried different keyboards but it´s all the same problem. The sustain pedal of course work´s great when using the line outputs instead of the midi outputs.
Macbook Pro 2Ghz, 2Gb ram. 002r |
check to be sure you don't have a MIDI filter blocking controller 64.
Quad 2.5 G5, 4.5G RAM |
Thank´s for the reply! W
Where do I do that?
Under the MIDI menu.
Thank´s it marked the "aftertouch" box and now it works!
that's interesting... aftertouch is a different controller from the sustain pedal.
Yeah, I thought so to.
Sustain pedal not working with pro tools 10 | Fyenamuzik | macOS | 4 | 03-30-2013 03:26 PM |
Sustain Pedal Not Working | Numi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-24-2009 01:34 PM |
Sustain pedal not working with Mini Grand | Gothboy | Virtual Instruments | 0 | 06-22-2009 10:31 AM |
midi sustain pedal not working in pro tools | protoolsle123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-14-2009 01:31 AM |
Sustain Pedal and Reason | cuethevocals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-18-2004 11:50 AM |
