Old 01-24-2022, 09:10 AM
Breezico Breezico is offline
Default Deleting Measures - Help!
Hi, this should be a simple one but I can't find it anywhere.
I have a song all set up and I just need to shorten the intro by deleting 12 bars, measures 5 to 17 across all tracks.
I'm looking for the same principal as deleting a word in a text document: that everything just shifts to the left, but I can find the command. when I hit delete it just clears the bars.
Can anyone point me in the right direction please?
Thanks
Old 01-24-2022, 12:44 PM
Bookerv12 Bookerv12 is offline
Default Re: Deleting Measures - Help!
If you put the edit mode in "Shuffle", the left boundary after your edit will snap over to the right boundary before the edit.
Put it in shuffle mode.
Select the bars across all tracks.
Hit delete.
bookerv12
Old 01-24-2022, 01:32 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Originally Posted by Bookerv12 View Post
Hit delete.
I think this will result in clips moving not equal distance.
I think what you want is:
Select the bars in timeruler.
Event menu: Time operations - Cut Time.
And welcome to the DUC.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16gb RAM. MacOS 11.6.3 Big Sur. Pro Tools 2020.12.1.191.
Focusrite Scarlett 6i6, Dynaudio BM6p, Command|8, SSL UC1.
Old 01-24-2022, 01:38 PM
You are correct.
Have to select measures in Grid mode, switch to Shuffle, delete.
(Wildly assuming he assembled his audio in grid mode)
bookerv12
Old 01-25-2022, 02:33 AM
Brilliant, thanks very much for your help, I had set up the audio timing so it selected fine. Tried the shuffle mode and after a bit of trying (I had to hit enter first to get the selecting right) I've managed to delete the bars required nice and neatly.
Cheers
Old 01-25-2022, 05:28 AM
Just set groups to "all" before selection and edit.
bookerv12
Still no answer. Deleting empty thousands of measures at the end of the session. Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-04-2014 12:37 AM
add measures How is this done ? mgmazzei macOS 3 12-29-2012 02:46 PM
Inserting/Deleting Measures Steve Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-17-2002 12:59 AM
Deleting/Copy MIDI notes is not deleting/copying MIDI sustain? Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 12:29 AM
deleting measures (in conductor ruler) ereiamjh Digidesign Hardware & Software 0 06-18-2001 01:05 PM
