Old 01-17-2022, 04:54 AM
DrewHarrison DrewHarrison is offline
Default Real-Time De-Breath Plugin?
Are there any de-breath plugins that can run real-time in Pro Tools? The RX and Waves ones cause too much latency to keep the delay-compensation working. Do any have low enough latency? I do not want to process this offline through the AudioSuite.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 01-17-2022, 05:20 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Real-Time De-Breath Plugin?
Realtime as in can use while monitoring singer, no. Realtime as in no need for AudioSuite, yes.
Janne
Old 01-17-2022, 05:21 AM
To use while mixing.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 01-17-2022, 05:52 AM
JFreak's Avatar
Have you tried ERA De-Essefr already?
Janne
Old 01-17-2022, 03:29 PM
Sardi Sardi is offline
Era De-Breath is what you want to try, not the De-Esser.
Unsure of the latency of that plugin. Try the demo.
Also, are you sure it’s just the de-breath plugins that are pushing your delay comp over the limit? I’ve used the Waves de-breath plugin in the past and don’t recall it exceeding the delay compensation limit. Do you perhaps have some other noise reduction plugins etc. on the tracks?
Old 01-17-2022, 04:01 PM
100%. If I create a new pro tools session and add just one single Waves DeBreath plugin, it's over the limit. It's using 32384 samples for buffer (according to the mixer window).
Cool, I'm going to download the demo and try it out, then report back.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
Old 01-17-2022, 05:22 PM
Yeah, these type of plugins that employ large look ahead buffers tend to be problematic in real time usage.
I honestly didn’t think it was that large with Waves De-Breath. I own it and tried it a few times but never really liked the results so just went back to manually de-breathing. To be fair, I probably just used it isolated and rendered the results. It’s been a while so hard to remember.
Definitely try Era De-Breath and see how you go. You may find that it suffers the same issue. I know the RX one does add a fair bit of delay as well.
Old 01-19-2022, 12:51 PM
Benoni's Avatar
Benoni Benoni is offline
What about using an Expander?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-23-2022, 02:04 PM
I'll play devil's advocate here and suggest using a little EQ to exaggerate it so the performer can hear and correct the issue instead of trying to put a band aid on it. Its similar to folks that think its a good plan to sing with AutoTune on instead of improving(so they don't need it at all or as much).
There are also some other ideas to solve the issue on the way in. A few ideas to try:
1-use a better(or 2) pop filters
2-rotate the mic slightly
3-angle the mic downward and raise it a bit.
I need a plugin that shows waveform changes in real time as I modify the sound. furosma AAX Plug-ins 7 05-06-2020 11:09 AM
PT 8 - RTAS Plugin Real Time (Auto Tune Evo) new dj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2009 03:51 PM
Real Time Analyzer app. or plugin? mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-04-2007 02:35 AM
Recording plugin effect changes in real time? darebear Tips & Tricks 1 11-17-2006 07:56 AM
Plugin:Real-time audio connection between PT users RadioMoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-18-2005 04:36 AM
