Old 02-22-2017, 04:22 PM
mmcl mmcl is offline
Default Interleaved check box
What is the Interleaved check box for on the quick start dialogue box in PT 12?
The only thing I can find that it affects is the output format selection when you go to bounce. Is that it? Seems a bit unnecessary, as that can be edited anyway.
Old 02-22-2017, 04:28 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Interleaved check box
It affects importing/creating files, and you can enable/disable any time in Setup > Session.
"When this option is enabled, all newly recorded or imported (and converted) stereo or greater-than-stereo multichannel files in the session will be interleaved audio files."
See pg 152 in the Ref Guide for more info.
linkedin
5.1 Interleaved Files rmccam Post - Surround - Video 24 09-04-2016 02:58 PM
Interleaved uses more resources? Frank Kruse Post - Surround - Video 15 07-15-2012 09:47 AM
2gb,check! firewire audio drive,check! samples.... bump!! MarkusB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2007 02:25 AM
SD2 interleaved and Jam polyorchid Pro Tools TDM Systems (Mac) 2 07-12-2001 04:45 AM
interleaved stereo--what is this norie Tips & Tricks 5 03-21-2000 08:28 AM
