Old 12-05-2012, 01:19 PM
Fyenamuzik Fyenamuzik is offline
Exclamation Sustain pedal not working with pro tools 10
Hi y'all,
I have a little problem with my pro tools at the moment. although I plugged in the pedal to the right place, plugged USB to my macbook correctly (on light), on my midi controller and checked ticks on the MIDI-> Input filter and input devices, when I press the pedal it will just 'mute' instead of blurring the sound. How should I make this work?
For Midi controller I use Akai MPK 88, pedal is YAMAHA FC3 and audio interface I use is M-audio fast track.
Old 12-05-2012, 01:27 PM
KMcK KMcK is offline
Default Re: Sustain pedal not working with pro tools 10
Sounds like it's plugged into a controller pedal port and not a sustain pedal port.
If that's not it, then you're going to have to figure out how to make the MIDI controller send sustain pedal data from the pedal instead of mute data. I would actually try a different sustain pedal first, Yamaha pedals tend to be a bit wacky when not used with Yamaha keyboard in my experience.
Old 12-05-2012, 01:43 PM
Yup. I think Yamaha pedals use opposite polarity on their sustain pedals.
You want a weird one for sustain pedal use in a VI? Check out NI's Vintage Organs. That's the one they have now instead of B4-II; it also has Farfisa and Vox Continental models. On the B3 emulation the sustain pedal is setup by default to control Leslie speed which is also controlled by default by the mod wheel on a MIDI controller.
Jack
QAPLA!
Old 03-30-2013, 02:15 PM
Sorry for late reply, you guys helped me a lot it is now working. In the beginning the pedal worked if I don't press down the pedal and if I press down it stopped which is the.. other way around but now it is working fine.
Thank you so much for the help
Old 03-30-2013, 03:26 PM
You had a pedal with reverse polarity - some pedals have switches to flip the polarity and sometimes things can be reversed by software. Would be interested to know what you did to get it working.
Jack
QAPLA!
Sustain Pedal Not Working Numi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2009 01:34 PM
Sustain pedal not working with Mini Grand Gothboy Virtual Instruments 0 06-22-2009 10:31 AM
midi sustain pedal not working in pro tools le 7.4.11 protoolsle123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-24-2009 04:50 PM
midi sustain pedal not working in pro tools protoolsle123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-14-2009 01:31 AM
Sustain pedal not working - Reason to PT LE totemspock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-12-2004 02:28 AM
