Problem with offline bounce
I have some side chain compression not coming through on an offline bounce. It is there when bounced in real time but not when using offline bounce.
Would appreciate any ideas/suggestions? Has anyone experienced something similar? |
If you're using hardware it's normal that it won't be there in the offline bounce. Offline are obviously not in real time, therefor no audio is being sent out to any outputs. You're hardware would probably not even be able to handle it if Pro tools did send audio to the output during an offline bounce.
I've explained the cause, and solution in these two threads.
Current Thread. Old Thread. Hope that helps. |
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct | Skwaidu | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-23-2015 03:55 PM |
HDX Offline Bounce bug | fsavell | Pro Tools HDX & HD Native Systems (Mac) | 0 | 08-28-2014 10:56 PM |
Offline bounce vs. Realtime bounce significant differences | Mano | Pro Tools 11 | 13 | 05-29-2014 05:58 PM |
offline bounce different than realtime bounce | grant howarth | Pro Tools 11 | 8 | 12-08-2013 09:29 PM |
Offline Bounce | DonaldM | Pro Tools 11 | 6 | 11-17-2013 08:56 PM |
