Old 09-18-2022, 08:22 AM
Mirko Cascio Mirko Cascio is offline
Default Eucontrol 2022.9 Crash
Good evening everyone.
Sorry my english.
I have installed the new eucontrol 2022.9.0.41 software. When I try to move the plugs on my S1 and Dock at the same time, it crashes. The app crashes on the Mac, it crashes both S1 and Dock and App on the tablet. I have to do a stiff exit from the application and restart the software.
Do you have a solution?
Thank you.
Mirko
Old 09-18-2022, 09:18 AM
Southsidemusic's Avatar
Default Re: Eucontrol 2022.9 Crash
Hi and Welcome to the Forum Community
Make sure to update the Eucon on both computer and ipad as they need to be the latest versions on both computer and ipad to work properly so download the new Eucon again on the computer and see if that fixes it.
Also check again you have the latest version of Eucon on the iPad.
Best Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-18-2022, 12:38 PM
thank you.
I uninstalled and reinstalled the latest version on the mac computer.
I have installed the latest version on the tablet. the problem is still present.
however, the firmware of the S1 and the dock have not had any updates. is there a way to refresh the controller firmware? thank you.
Mirko
Old 09-19-2022, 07:28 AM
Will ask and post back otherwise we have to look at the next step to get it working. Also maybe someone who has the S1 and dock can chime in?
Originally Posted by Mirko Cascio View Post
thank you.
Mirko
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-19-2022, 08:32 AM
BScout BScout is offline
I'm unclear what you mean by "move" and "at the same time."
Move: is that remove? or create (instantiate/add)?
At the same time: how are you doing this on two controllers at once? You either do the action on the S1 or do the action on the Dock. But never exactly at the same time. (I would not understand the reason for this either.)
As for firmware updates, you do it from the Surfaces tab in EuControl. Select the item from the "My Surfaces" section and then choose "update firmware" at the bottom. You can't update a device that is already current. And there would be no point.
What sometimes helps with problems is to restart the device. Power cycle the S1 (by pulling the power cable and then plugging it back in.) Power cycle the Dock by turning the switch off and then on. Or rebooting the whole tablet (each tablet type has a different way to do this.)
But it sounds like your problem is software related so hardware changes (including firmware) would have no affect.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 09-19-2022, 09:25 AM
Iain Haworth's Avatar
Iain Haworth Iain Haworth is offline
Hi Mirko,
Can you let me know what plugins you're using and what kind of tablet you have? I can try and reproduce the same behavior and go from there
Old 09-19-2022, 11:16 PM
Hi BScout,
I use dock and S1 at the same time, to extend parameters over 16 knobs, trying to use the custom function.
Thank you.
Mirko
Old 09-19-2022, 11:19 PM
Hi Iain,
on each plug, I usually use SSL Ch strips. The tablet is a standard android.
Thank you.
Mirko
Old 09-20-2022, 10:04 AM
Hi Iain,
Thank you.
Mirko
Thx for the info Mirko - I don't have the SSL Ch strip plugin but I tried a bunch of other plugins and couldn't get the same behavior you're seeing. Could you try using the stock Channel Strip that comes with Pro Tools and see if you get the crashes?
Old 09-20-2022, 11:41 AM
HI, Iain,
I have actually tried only plugins from the SSL bundle that have this problem.
I have tried other brands, like, msdsp, fabfilter etc etc .... and it seems to be ok.
Thank you
2022 Crash Behaviour in Windows. Anyone? lesbrunn Pro Tools 10 08-17-2022 02:23 PM
Artist Transport and EuControl 2022.4: different issues Megalobass Artist Series 1 06-12-2022 06:37 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
EUCONTROL 3.0.1 Crash continuously on 10.8.4 & 5 tizi66 Artist Series 2 01-03-2014 04:25 AM
eucontrol crash Mexadon Artist Series 0 02-13-2013 12:21 PM
