Pro Tools signal generator sine wave creates harmonics / overtones?
Hello there,
Is it normal that Pro Tools' sine wave generator creates harmonics / overtones? Or is it the Pro Tools engine creating the overtones? |
Re: Pro Tools signal generator sine wave creates harmonics / overtones?
Is it happening with less than 0,0 dBfs, too ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Well it happens at -3.1 rms sine upwards, not in peak mode obviously, not enough level.
But when I put it to 3.1 where the overtones don't happen and add a trim plugin, compensating for the missing 3.1, no overtones whatsoever. Is that a built in feature? Or a bug? Last edited by atticmike; 01-19-2017 at 08:01 AM. |
From wikipedia :
"RMS: For the case in which the RMS value of a full-scale square wave is designated 0 dBFS, all possible dBFS measurements are negative numbers. A sine wave cannot exist at a larger RMS value than −3 dBFS without clipping by this convention." The clipping produces those overtones, so I would not call it a bug but physics/mathemetics.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 01-19-2017 at 09:17 AM. |
Sine wave generator in PT does not generate significant harmonics. I see nothing but red lights in your screen shot, so yes, everything's clipping.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Don't throw in physics and mathematics if you can't recite fourier formulas... Quote:
Anyways, solved it, it is the signal generator which generates some kind of harmonics past -3.0 rms. Last edited by atticmike; 01-19-2017 at 03:24 PM. |
Right above, you can see the bluecat analysis tool. which has nothing to do with channel strips if the metric halo plot irritates you.
Where in the chain is the BC plugin - before or after the MH plugin? To make your point that the signal generator is creating harmonics you really need to have the BC plugin before the MH strip and not after. Because if it's after you're not really able to prove your point about the generator plugin right?
The screenshots are a bit too fuzzy for me to tell what's going on, and I'm not gonna dig into this deeply, but it is worth saying that the PT sig generator has never been the cleanest thing out there - sufficient for checking gain structure, setting interface levels, etc, but I certainly wouldn't rely on it for any kind of real "analysis". If I need pure tones for distortion tests, linearity sweeps, aliasing tests, etc, I generally use the programmable generator in Spectrafoo which works quite well and can do just about anything I need. That said, those screenshots sure look like something else is going on - distortion products 10dB down - seems like clipping somewhere in the chain to me...
Swept Sine Wave | ichbin | Pro Tools TDM Systems (Mac) | 5 | 11-05-2006 02:02 PM |
making Virus sound like a sine wave signal | Felix | Pro Tools TDM Systems (Mac) | 4 | 01-13-2005 02:55 AM |
Generating a sine wave in Protools | waves3 | Pro Tools TDM Systems (Mac) | 16 | 11-15-2004 11:36 AM |
001 hardly dealing with a 15k sine wave ???!!! | jinglemaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-09-2002 02:45 AM |
AS Signal Generator - funky sine wave | jimlongo | Pro Tools TDM Systems (Mac) | 1 | 03-07-2000 01:53 PM |
