Old 09-24-2022, 09:08 AM
Chevron Chevron is offline
Default Avid S1 Custom Mapping
I am just learning to use custom mapping with my newly arrived S1. One thing I have not worked out yet is with Softube's Console 1 channel strip and mapping buttons.
When selecting INSERT on the S1 and then navigating to Page 3 which displays the EQ parameters, it is actually laid out how I want it. But when selecting EQ on the S1 - the layout is similar but has different assignments for the buttons.
For example Knob 1 on INSERT / Page 3 controls Low Gain with IN switching the channel EQ in and out - perfect. Knob 1 on EQ Page 1 controls Low Gain but IN controls shelf and bell curves.
So I've tried to copy the INSERT Page 3 layout to a custom map for EQ but I can't find the EQ in and out parameter to assign?
Pro Tools Studio 2024.3| Eucon 2023.11 | Mac OS 14.3.1 | Soundflow | Streamdeck | 16" Apple MacBook Pro M3 Max 16 Core 64 GB RAM | 2020 MacBook Pro 13" M1 16 GB RAM | Hackintosh i9 9900KS 32 GB RAM
Old 09-24-2022, 09:25 AM
BScout BScout is offline
Default Re: Avid S1 Custom Mapping
Insert options are up to the manufacturer.
EQ options are defined by Avid for EQ.
They won't all be the same.
You should just use Inserts. There's an option in Eucontrol specifically for this problem on General tab.
"Show EQ/DYN plug ins on surface as Inserts..."
Check the box.
Old 09-24-2022, 11:03 AM
Check the box.
Thank you for the info on Insert and EQ options.
If I understand you correctly, if I create a custom map in Inserts and then check the "Show EQ/DYN plug ins on surface as Inserts" preference my Insert custom map will show when i press the EQ button on the S1?
Old 09-24-2022, 05:23 PM
Close.
If you have a custom map, when you select the plugin, the Channel Tab will auto go to Insert (with the custom map) instead of EQ -- which gives you more options than EQ.
Old 09-25-2022, 09:31 AM
Close.
Got it thanks.
S1 Custom Mapping not working traksion Avid S1, S3, Dock and Control App 4 07-25-2021 09:31 PM
S1 custom mapping FF-Q3 Frank Kruse Avid S1, S3, Dock and Control App 6 07-21-2021 07:57 PM
Custom plugin mapping marsian Avid S1, S3, Dock and Control App 2 05-29-2019 07:45 AM
AVID please help! Updated to Eucon 3.3.2 and all my custom mapping GONE! bobbyguelz Artist Series 0 01-07-2016 04:46 PM
Mapping to custom faders dunebuggy Pro Tools 10 4 06-29-2015 08:51 AM
