blue screen on first boot, can\'t uninstall
Hi all and thanks for helping,
I just bought a brand new Dell i6000 w/ XP Pro specifically for Digi b/c it was listed on the "approved" list on the spec sheet for ProTools 6.7 w. Mbox, which I have. I tried to install 1 hour after the machine arrived. During install I got a warning message - something about the software not being MS Logo certified. I ignored that since i had it running on another XP Pro machine. On first launch, blue screen of death. I've had this computer for 90 minutes! I tried to uninstall, and the software won't. It's stuck on a partial install. The digi directory is there, but only part full (comparing to a healthy install on another machine). I searched the knowledge base and found something about a DEP fix...that might account for the first issue. But what about the inability to uninstall? Many thanks, d |
Re: blue screen on first boot, can\'t uninstall
Hi everyone,
I'm replying to myself, to supply more info. * Tried to install over the current partial install, and halfway through got an error dialogue box that says: Component transfer effor Component: Program Files File Group: PT Folder Icon File: <iconPath>\ Error The filename, directory name, or volume label syntax is incorrect. I can not install or uninstall at this point. So typical...invest in the better, "known compatible" machine, and it craps out. Bummer! |
in my experience, the best thing to do with Dell systems is to find the Windows XP and drivers install CD and start fresh. (if you have an SP1 install CD, use that)
there is so much crap on these machines straight out of the factory that anything could be causing the problem. also, enter the BIOS setup programme and check that wireless networking, etc. is disabled. |
Solved this finally. Here's the update, for the archive:
Dell tech support walked me through a factory restore. On boot, when the dell logo comes on, hit Control->F11. You should go to a screen that enables you to restore. It took me three tries to get it timed right, so be patient. This will take you all the way back to "out of the box" condition...you'll have to name the computer and everything. But, it only takes 10 minutes and can be redone as needed, whereas a clean install takes hours. I believe this is unique to the Dell machines, but I don't know that. Others may have a similar process. The tech then walked me through a process that I can not remember well enough to detail here, but the result was it turned off DEP. We did that at the command prompt. The tech found the solution after I read him the "0xXXXXXXXXX" number that appeared on my "blue screen of death", and he did some research. I did NOT use this fix found in the Digi Answerbase for turning off DEP: http://answerbase.digidesign.com/detail.cfm?DID=29096. But I suppose that might be something to try before you resort to tech support. Since restoring the computer (not using Restore Points, but as described above) and turning off DEP, and reinstalling ProTools LE, everything seems to work. Hope this helps. Best, d |
blue screen | vikingthor | VENUE Live Sound Systems | 0 | 03-01-2011 07:40 AM |
Win 7 Blue Screen | ninjaroach | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 12-12-2010 06:52 PM |
Blue screen on boot (YES I've done my homework!) | Rusherific | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2005 03:10 PM |
My first ever XP Blue Screen...help?? | murph16 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-05-2003 01:56 PM |
The Blue Screen | RDOG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-18-2000 04:14 PM |
