Old 10-22-2003, 09:53 AM
Studio Dweller Studio Dweller is offline
Default L2 won\'t sync to 192 Word Clock
I can not get my rackmount L2 to sync to the word clock out on the 192. The 192's clock source is set to 'Internal' and the word clock out is set to output word clock at 44.1 KHz. The L2 is set to sync to 'External', but it won't lock. The L2 and the 192 will sync to my Rosendahl Nanosyncs using the same cable. The Nanosyncs will also lock to the word clock out of the 192 so it appears to be some kind of incompatibility between the L2 and 192 I/O.
I called Digi last night and they had one other documented call with the same problem, but no solution to offer. Does anyone here successfully have an L2 clocking to a 192? My next move is to call Waves.
Thanks,
-Larry
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 10-22-2003, 10:49 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: L2 won\'t sync to 192 Word Clock
interesting ... all I can offer is to try it at my studio. My L2 is clocked to an Aardsync II, I could try to sync it to a 192 and see what happens.
Chris Lambrechts
Applications Specialist- Live Sound
Old 10-22-2003, 10:57 AM
Chris, if you wouldn't mind doing that, I'd certainly be interested in seeing if you experience the same thing.
Thanks for the offer.
Larry
Old 10-22-2003, 07:07 PM
fifty8th1 fifty8th1 is offline
Can the L2 be syned to the Digi Superclock... know what i mean.... times 256 Fs.
I know my Big Ben wouldn't work with our 888-24 until I set it to fs 256.
jon
58Th Street Studio
Old 10-22-2003, 11:41 PM
the dude's Avatar
the dude the dude is offline
[b]
unfortunately the Sync I/O word clock output is only around 3.5v p/p
and some gear prefers to see at minimum 5.0v p/p you will have to go through a WC distribution amp for this one to work . FYI the Tascam DA88 and the Sony PCM800 almost never lock to the Sync I/O WC clock
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 10-23-2003, 06:50 AM
I'm trying to sync the L2 to the 192 I/O, not the Sync I/O, but it sounds like it's probably the same issue.
My Rosendahl Nanosyncs successfully locks to the 192 word clock so I could do that and then lock the L2 to the Nanosyncs if need be.
Thanks very much for the info.
Larry
PT8//Word Clock//Loop Sync//Big Ben whatsprotools Pro Tools TDM Systems (Mac) 13 02-27-2009 10:56 AM
Word clock sync goga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-11-2008 11:28 AM
Word Clock and SYNC on an 003r Elecshop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2007 10:21 AM
Sync I/O Word Clock Output budster Post - Surround - Video 0 02-14-2007 09:03 AM
Digimax word clock sync bsjaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-19-2002 06:36 PM
