Old 03-24-2011, 09:50 AM
geitz geitz is offline
Default Loudness measurement/adjustment in the broadcast chain
Just had a conversation with an engineer at a local network affiliate. He said they are mostly still using the 0 VU spec to check levels on ingest of local content to their streaming server, but they also have one of these in the chain before transmission. How can it do dialnorm metadata creation in real time when dialnorm is a long-term measurement?
Greg
Old 03-24-2011, 11:08 AM
Postman Postman is offline
Default Re: Loudness measurement/adjustment in the broadcast chain
"Loudness control using multi-band multi-stage AEROMAX dynamic range engine"
I'm not sure what that means but I'll guess it is the usual compressor/limiter approach that we all know so well.
Old 03-25-2011, 08:18 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Yikes Run for the hills!
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 03-25-2011, 04:29 PM
Local affiliates have a long way to go. This was discussed at this past AES. Unless you are working on content that is only airing from this network affiliate, you and your clients are best served by mixing to the parent network's specifications. Go to atsc.org, run a search for A85, and read that document for what to do if the network doesn't give you specifications.
Old 03-25-2011, 04:39 PM
dr sound's Avatar
dr sound dr sound is offline
Go here for the A85 Document:
http://duc.avid.com/showthread.php?t=87830
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 03-26-2011, 09:47 AM
Wellnitz Wellnitz is offline
Hi Greg,
i strongly recommend you to watch the webinar from Florain Camerer.
It takes you a step further from ITU 1770 to EBU R128.
I think the recommendations for the US are from the ATSC.
http://tech.ebu.ch/events/webinar_lo...e/off?id=13224
regards
Jochen
Old 03-26-2011, 09:59 AM
Sorry Greg,
you asked about the measurement in the transmission chain.
We use the juenger C8000 levelmagic. I think there are no great differences between the two boxes.
In the juenger software you can set a target loudness level and a time for measuring. Cause the box is in the transmission chain you won´t set a time for each show. One time for all.
http://www.junger-audio.com/fileadmi..._EN_090612.pdf
regards
Jochen
HTML code is On
CALM Acts Audio Loudness, Average Loudness, Program Loudness levels... help needed qr2r Post - Surround - Video 12 11-10-2011 01:41 AM
Loudness during broadcast DJH Post - Surround - Video 36 03-31-2009 05:51 PM
LIP SYNC (measurement) Eric Seaberg Post - Surround - Video 2 05-26-2008 06:25 PM
Audio measurement software Gunnar Hellquist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-10-2004 04:28 PM
Broadcast level, compression, loudness... TheMixShop Pro Tools TDM Systems (Mac) 2 04-01-2004 10:50 PM
