Old 11-28-2007, 08:25 AM
iamherenow iamherenow is offline
Default midi keyboard controller problems...
I'm about to lose my mind about something I know is simple. I use Reason 3.0. I use a Edirol PCR-500 as a controller. The problem is whenever I attempt to play keys (strings, bass, etc.) to my drum tracks, every note I play sustains continuously without me using the pedal. I have to click stop on the Reason transporter to get it to stop ringing. Also, when I play certain notes it triggers or plays some of my drum patches from the Redrum. Is there a way to turn this off as well? HELP!!!
Old 11-30-2007, 07:04 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: midi keyboard controller problems...
ONe possibility that comes to mind is to check the polarity on your sustain pedal. Some pedals are the opposite of the keybaord's, so they sustain when "up" and cut off when pressed. It might be your controller sees the pedal as pressed and is sending the sustain info to Reason. try unplugging it altogether and see what happens.
As for the Re-drum trigger, you have to tell it to not pay attention to a midi start signal, basically. You should be able to do this by clicking on the "run" button on Re-drum to turn it off. With run on, any note you play will automatically start up whatever sequence is in Re-drum. I found this out the hard way, too.
Hope this helps.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Which Midi Keyboard Controller? Paul PT Virtual Instruments 6 04-20-2008 03:26 PM
Midi keyboard and controller? pertrot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-03-2007 08:21 AM
MIDI Keyboard Controller / PT milet22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-04-2006 03:20 PM
midi controller keyboard?? Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-14-2004 02:35 PM
Midi Keyboard Controller secutanudu MIDI 0 02-16-2003 03:46 PM
