Old 09-11-2006, 04:30 PM
musicnutt2000 musicnutt2000 is offline
Default Delay Compensation on Master Fader
I am just getting back into PT after a short break with Samplitude. I have a PT HD2 system with 7.2 software. Most of the time I mix with several plug-ins on the master fader. Just wondering if it makes sense to disable delay compensation for the master fader only?? The delay compensation for the master fader would be around 4000 samples, and would exceed the short delay compensation setting. I have delay compensation enabled for all other tracks. Does this make sense or am I missing something??
Also, I usually have about 3 auxes setup. I have noticed that the delay compensation for my aux sends are very low (aux 1 is TL Space - 3 samples, aux 2 is Rverb - 3 samples, aux 3 is slap dly - 3 samples). Is this normal?
Just trying to make sure that my mix is delay compensated properly.
Thanks.
Old 09-12-2006, 04:08 AM
25ghosts 25ghosts is offline
Default Re: Delay Compensation on Master Fader
you could set the delay compensation to LONG instead of having it set to short...Also you could delay it manually either on the fader or with a short delay(this is cool if u only use like 4 or 8 master outs
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Is delay compensation necessary for Master Fader on Main Outs? WinTaper Pro Tools 10 1 02-19-2014 05:57 AM
Delay Compensation on Master? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-19-2011 12:10 PM
Manual Delay Compensation on Master Fader? browniespeaks Tips & Tricks 11 05-05-2010 10:34 AM
Bypass Delay Compensation on Master Bus? Dizzi45Z Pro Tools TDM Systems (Mac) 6 05-16-2008 09:15 PM
Can you disable Delay Compensation on Master? AINSLIE Pro Tools TDM Systems (Mac) 7 02-15-2008 09:56 AM
