#21
Re: Pro Tools HD 9 Software Upgrade - From what?
If you own a HD core card you can purchase HD 9 for the upgrade price $349 this gives you the HD system that will run with the TDM cards and interfaces and also run under coreaudio with any interface. under coreaudio no TDM cards or plugins can be used nor can the HD interfaces. If you don't own a HD system then you can't buy the HD upgrade!! but can buy pro tools 9 (which will run natively! but will not run with HD cards and hardware under DAE! when running natively you cannot use any HD Cards or TDM only plugs) pro tools 9 will only run under coreaudio or asio. pro tool 9 has some features missing from the HD version; only 96 tracks. 1 video track. no vca tracks. etc. If you want to have pro tools 9 with the full "software" features and track count of pro tools HD9 then you'll have to buy the complete production tool kit!!!! (about $2k+) There is a lot of confusion between pro tools 9 / pro tools HD 9 / pro tools 9 full version Pro tools HD 9 upgrade $349, only available to HD owners with a core card serial pro tools 9 full version $599, for people with no upgrades. restricted features over the HD version!!!! pro tools 9 upgrades, from $99-$349. upgrade from LE or M powered You can not buy the HD version unless you already own a HD system!!!!! only upgrade is available. No! when HD9 is running natively it does not have the same power as when running as a HD TDM system. no TDM power is available! the cards are redundant, all you have is your computer CPU for everything!! Chris
#22
Can I use my HD PCI core card serial # to upgrade to PT HD 9? I assume the answer is yes, but I'm not going to fork out $350 to find out I'm wrong.
Can anyone from Digi or anyone anyone else confirm this? Thanks! |
#23
yes... we can say it once again. The PT HD9 software is tied to a hardware core serial, so even if your core card is broken you can use the serial to get the software and run it without TDM features on a Macbook or whatever.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
#24
imagine the following:
i have pro tools hd 7 and i can upgrade with its serial to pro tools hd 9. let's say i made an image of the disk before i did the upgrade. now i can run pro tools hd 7 (with the hardware) from the image i've made on one computer AND pro tools hd 9 with core audio on another computer!? |
#25
I believe both versions would need an ilok license. i don't believe the license for 7 is hard disk based.
#26
Not at the same time unless you have the backup ilok from your HD7 rig. But yes you can use HD9 on the two machines as described.
Sent from my MB200 using Tapatalk |
#27
#28
Jason |
#29
by my understanding of the Transfer of Ownership this is a violation http://avid.custkb.com/avid/app/self...p?DocId=363631 and personally if I bought a card that I though was going to be able to upgrade but found out that it was used and ineligible I'd be pissed at the seller.
#30
For PT9HD you need a PT9HD license and HD hardware. If you have a PT9HD license but are running on a system without HD hardware you get PT9+CPTK. You have a PT9 license you get basic PT9. You have a PT9 license and a CPTK licence you get basically PT9HD but no TDM support. And that last scenario will not allow you to run PT9 on a HD system. You still need the hardware and the license to run PT9HD. Does that make sense?
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Pro Tools 7 LE/8 Upgrade Software | Sinical | Windows | 3 | 07-24-2013 05:12 PM |
Pro Tools Software upgrade | dclift | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-26-2013 07:59 AM |
Wtb pro tools HD 10 software Upgrade from HD 8 | keba | Buy & Sell | 1 | 01-29-2013 05:39 PM |
Wtb pro tools HD 10 software Upgrade from HD 8 | keba | Buy & Sell | 2 | 01-27-2013 12:23 PM |
Q: If I recently purchased a Pro Tools LE software upgrade—how do I obtain Pro Tools | dmm | Pro Tools 9 | 0 | 11-12-2010 10:14 AM |
