Old 06-26-2022, 09:29 PM
Just Phab Just Phab is offline
Default PT 2022.5 M1Max macOS 12.4 Monterey Won't Load
Hi PT Fam
PT hangs indefinitely while loading plug ins. It seems to stop on AirCompressor.
Anybody got any clues?
Been real nightmare unable to find any intel on what is supported.
Mac Studio
M1
1TB SSD HD
64G RAM
Old 06-27-2022, 12:59 AM
Default Re: PT 2022.5 M1Max macOS 12.4 Monterey Won't Load
The clue is that a plugin is preventing Protools from loading. Start by moving ALL plugin out to the unused plugins folder and relaunch Protools to verify it is working first. Then start moving the plugins back in one or a few at a time and relaunch each time to check if there are any problems. Once you identify an offending plugin, move it out again and continue through the rest of your plugins. After you've identified any problem plugins, check for updates and contact the manufacturer to verify compatibility with your OS, Computer, and version of Protools.
Obsidian Dragon
MacOS 13.6.4 running Protools 2024.3
Mac Studio M1Max - 64GB
MacOS 14.3.1 running Protools 2024.3
Old 06-27-2022, 08:49 AM
Franklyn Franklyn is offline
does it quit or hang?
does this happen when starting PT or opening a session?
is it the first time you open PT?
when opening PT the first time PT is scanning all plug ins and if there are to many plug ins to scan it is "normal" that PT quits at a point.
so you have to remove half of the plug ins out of the folder at the first run.
Air plug ins should work fine with your system.
Old 06-27-2022, 02:25 PM
s.d. finley s.d. finley is offline
Hi PT Fam
Mac Studio
M1
1TB SSD HD
64G RAM
According to AVID 12.3 is supported. Avid make no mention of 12.4
sdf
www.sugarhillstudios713.com
Old 06-28-2022, 07:49 AM
Universal Soundz Universal Soundz is offline
It's not just one plugin, I have the exact problem with the same M1 system 12.4 I think it's an AVID support problem.
Old 06-28-2022, 07:50 AM
So what's the fix is AVID coming out with any updates ?
Old 06-28-2022, 08:12 PM
It's a plugin problem. Do the procedure of moving ALL plugin into the unused folder, relaunch, and then start moving the plugins in one (or a few) at a time, relaunch, to test for problematic plugins. There is no getting around this process. Do it. Avid is not fixing 3rd party plugins.
Obsidian Dragon
Old 06-29-2022, 07:08 AM
I did the procedure and it happens on all plugins, it all work before but all of a sudden it doesn't I don't think it's a plugin problem.
Old 06-29-2022, 09:53 AM
_JJ_ _JJ_ is offline
Excuse my dumb idea but if your MBPro has been asleep you may need to restart it. PT does not like sleep even if it's not running when the machine nods off.
Old 06-29-2022, 10:09 AM
Raphaeld Raphaeld is offline
I’m using 12.4 on a Mac Studio Ultra and PT works fine.
EuCon Not Working macOS Monterey Mixmaster Rick Pro Tools 20 02-01-2023 06:50 AM
Pro Tools 2022.4 CRASHING upon LAUNCHING on Monterey 12.3.1 nightowls Pro Tools 7 06-10-2022 01:16 AM
Avid Quartet and macOS Monterey gng75 Pro Tools | Duet & Pro Tools | Quartet 0 04-24-2022 05:41 PM
macOS Monterey 12.3 officially supported! DerrickC Pro Tools 62 04-01-2022 01:31 AM
Mbox3 pro MacOs Monterey SIP suggested Madsvigeholm macOS 5 12-28-2021 09:25 AM
