Sync problems between PT9 and Reason 6
This is a problem I've had for a while and have seen other posts with the same problem, but no answers. I hope that there's someone out there that can help! I'm running Pro Tools 9.0.3 and Reason 6. When I play a song (even just a couple tracks in PT and no instruments in Reason, just watching the timelines) the sync is off. For example, if I have a certain change that comes in at bar 84, if I start before that bar, the change happens at bar 84 when looking at the timeline in Reason. However, if I change the buffer to 128 or less and I start a little before bar 84, watching the timeline in Reason, the change comes too early. I did see where someone else was asking about the cursor speed in Reason. This is another way to look at it. With a higher buffer, the cursor moves quickly (normal) and is synced with PT. With a lower buffer the cursor moves slowly and is out of sync with PT. I searched on here and the Reason forums page, along with google searches. I have performed the General Troubleshooting that is listed on this site along with the setup guide. And I know about running Reason in 32 bit mode, so that is not part of the issue. My specs are: Mac Pro 2.8 GHz, OSX 10.6.4, Digi 003 rack+, Pro Tools 9.0.3, 12 GB Ram, OWC Mercury Elite AL Pro external hard drive for record/playback connected by firewire. No other peripherals are attached. Thank you! Paul
Mac Pro, 2.8 GHz Quad-Core Intel Xeon, 32 GB Ram, Digi 003 rack+, Pro Tools 12.5.2, OWC Mercury Elite AL Pro 1 TB |
PT 6 sync with Reason | DEA | Pro Tools TDM Systems (Mac) | 6 | 03-02-2003 11:28 AM |
PT Refuse Reason playback sync problems | Rainy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-05-2002 11:57 PM |
PT Sync with REASON on another PC | pmh3r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-25-2002 08:40 AM |
sync with reason via oms | scdreger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-11-2002 08:52 AM |
Sync REASON to PT | andyo | MIDI | 1 | 07-20-2001 11:40 AM |
