Pro Tools M-Powered doesn't permit the install on a different drive - Snow Leopard
Hello everyone,
I'm trying to install Pro Tools M-Powered 8 on my Macbook, but each time that I try to change the install directory, it returns to the warning screen that says it could be a conflict between Mac OS and PT shortcuts ("Default Toggle Shortcut..."). I made two partitions in my hard drive: one to the system and the other to aplications and audio files (detail: either when I try to install the drivers of my interface is permitted the installation in the audio partition). Both of them are formatted as a Mac OS default file system (HFS+). Is there any configuration or other formatting type that I should do? Sorry if I'm posting a answered question but I can't find this in the software manual, any thread of the forum or google search. Does anybody could help me? Thanks in advance! |
Re: Pro Tools M-Powered doesn't permit the install on a different drive - Snow Leopar
You shouldn't do that. Pro Tools (and any other application that installs system level drivers) needs to be installed to the same drive and partition as the OS. You should install to the default location and do not move any components after install.
Thanks for the answer!
But for now, I'm a little bit confused... The software manual says that we shouldn't work with audio in the same directory of the system files, otherwise some kind of delay could happen. So it only refers to the track files (data wave/MIDI files that we record) and not to the software ones, correct? Thanks! |
The Pro Tools application itself should be installed in the OS partition. Recorded audio should be recorded to a separate physical HDD. Not a partition on the OS drive. A firewire external drive is a good choice, as USB is not supported.
Thanks all for the answers!
It's clear now! |
OSX does disk management well. I wouldn't bother partitioning the system drive, unless you are booting up a completely separate OS from the second partition.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
I registered to the forums just to say that this is a horrible design decision, not allowing users to install to different drives.
My startup drive is a 40GB solid state drive, I'm not going to waste 12 GBs of that just on your software. Even the 2 GB install is too much to ask for, your program isn't worthy. |
Leopard to snow leopard clean or update install | joji | Pro Tools TDM Systems (Mac) | 10 | 01-01-2011 02:21 PM |
Help With the Steps for Snow Leopard, Pro Tools 8 Install | offshoretechman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-31-2010 07:06 PM |
pro tools m-powered essential on snow leopard | jakegreenie | Pro Tools SE and Essential (Mac) | 16 | 01-19-2010 12:41 PM |
Can not install Pro Tools Essential on Snow Leopard | andybarbo | Pro Tools SE and Essential (Mac) | 9 | 01-19-2010 12:40 PM |
Couldn't get snow leopard install to stabilize from leopard clone update! | crizdee | Pro Tools TDM Systems (Mac) | 2 | 01-11-2010 04:45 PM |
