  #31
Old 04-27-2022, 10:13 PM
bluecataudio's Avatar
bluecataudio bluecataudio is offline
Blue Cat Audio
Default Re: Univibe plugin
Originally Posted by musicman691 View Post
I haven't yet but that'll be my next step. I wanted to wring it out in a 'normal' setup before getting funky with it. Also going to try an Echorec emulation in the chain as well.
A definitely "vintage"-style setup then, that's great!
  #32
Old 04-28-2022, 02:33 AM
junkgear's Avatar
junkgear junkgear is online now
Great sounding vibe. My new fav, thanks!
Will
System Details
  #33
Old 04-28-2022, 02:03 PM
Sprung for the Blue Cat Vibe - great plugin. Tried it in Late Replies on the input, output and the feedback loops of Late Replies. That did not go well. No matter the position and using the default preset the effect was almost inaudible; could hear it but the strength was WAY down as compared to running it after Late Replies in a separate insert.
Jack
QAPLA!
  #34
Old 04-30-2022, 12:50 AM
Blue Cat Audio
Uni-Vibe is indeed a rather subtle effect that works better on smooth signals, so it would indeed probably sound good on reverb tails but a bit too thin on individual delay taps.
  #35
Old 04-30-2022, 05:10 AM
Could be but I was surprised that even when Polyvibe was in a slot at the output of Late Replies the effect was less pronounced than if it was the next plugin in the insert chain outside of Late Replies. That shouldn't make any difference. Not talking about volume but depth of effect - much less when in a slot (not in a feedback loop) in an output insert in Late Replies than when it's outside of Late Replies in a PT insert slot.
Jack
QAPLA!
  #36
Old 04-30-2022, 07:57 PM
noah330 noah330 is offline
Originally Posted by WorldStudios View Post
There is a good one inside Line6 Halix Native. In fact, I find most of the Line6 effects to be spot on and very close to the real stomp boxes that they emulate. It is expensive and complicated, sure, but the sound is right.
I had the opposite experience. I bought an HX so I wouldn’t have to take my cheap when I bought them now crazy pedalboard out.
Klon, Fender Reverb Unit, DM-2, sg-1, CE-1 and pn-2.
HX doing the same chain didn’t sound good let alone close. Plus it didn’t switch my SLO-100 and L6 sent it back to me ‘fixed’ and it still didn’t.
I think if you’re not putting it next to the real stuff the HX is probably cool. I found it hard to use and sound was meh.
Ymmv
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
  #37
Old 05-01-2022, 11:50 PM
Blue Cat Audio
All the effects in Late Replies only apply to the "Wet" (delayed or reverberated signal"), so placing the UniVibe plug-in after it in the chain indeed does a different job, as it applies to both the dry and wet signals.
  #38
Old 05-02-2022, 05:35 AM
Thanks - that explains a lot. Looks like I'll be using Polyvibe as a separate effect after Late Replies just like I would if it were a stompbox.
Jack
QAPLA!
HTML code is On
Plugin Window is too small cutting off access to most of the plugin GOOOTOOO Pro Tools 2020 7 09-21-2020 07:38 PM
Schoeps DOUBLE MS PLUGIN (2018) SURROUND PLUGIN FOR AAX finally available! bartosz idzi AAX Plug-ins 1 12-16-2018 03:49 AM
Bug: When selecting a favorite plugin insert, the plugin above the one selected opens DJ Hellfire Pro Tools 12 35 08-22-2017 08:05 PM
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 klyg Artist Series 2 02-29-2012 10:50 PM
Chorus sounds like a Univibe? Karl Houseknecht Eleven Rack 6 06-02-2011 07:16 PM
