Old 10-14-2004, 10:29 AM
Jason Kardong Jason Kardong is offline
Default [Q] Importing tracks from HD Recorder (Korg D1600)
I have a friend who wants to bring all his songs into ProTools from his hard disk recorder which is a Korg D1600. It has MIDI and optical out. I think each song has about 16 tracks so would take a couple passes.
Is there an easy way to bring these songs into ProTools via my Digi002? How do you sync up the Korg D1600 to Digi002. Is it as simple as connecting the optical to the Digi002?
Any ideas or pointers where I can read about this?
Thanks!
Jason
Old 10-14-2004, 10:42 AM
Default Re: [Q] Importing tracks from HD Recorder (Korg D1600)
Does the Korg D1600 support MIDI Time Code?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-14-2004, 10:49 AM
Hi Rail,
Yes, I believe it does.
Thanks
Jason
Old 10-14-2004, 10:52 AM
Then find my checklist on the DUC for synching the Mackie to Pro Tools LE.
Checklist
Once you've confirmed that Pro Tools chases the MDM, feed the optical digital from the MDM to Pro Tools and set the Pro Tools clock to ADAT input.
Rail
Platinum Samples
Old 10-14-2004, 11:11 AM
Riad Riad is offline
The best way would be to export the tracks to the build in CDBurner. Then do an audio import from the CD into a PT session. All the .wav files will be at zero start point, and even if you have only 4 tracks it will still export all 16 tracks so you would then delete them inside of PT.
www.carvelstudios.com
korg d1600 being slave a slave to pro tools sbag MIDI 0 04-12-2007 06:50 AM
More than 32 tracks using external recorder? CountZer0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-23-2005 01:32 PM
Importing from a Korg D-16 Brady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-30-2002 01:33 PM
Tracks for live show...Laptop or 19" HD recorder? netsucka Tips & Tricks 2 07-22-2002 02:19 AM
Sync with an external recorder like a Korg D16 or Roland recorder yoshi68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-17-2001 08:30 AM
