Old 05-19-2016, 01:19 AM
hj0102 hj0102 is offline
Default S3 Display font size problem
Hello,
It was working fine till yesterday, but font size has been changed as picture. OS is 10.11.4, Eucon version 3.4.11171610.
It happened same when I install Eucon 3.2 on El Capitan. After I go back to 10.9.5 and 3.2 works fine. However, after I checked that there's 3.4 which supports 10.11. Upgrade both. However, it happens again.
Any idea? Thanks in advance
Old 05-19-2016, 01:20 PM
Default Re: S3 Display font size problem
Somehow, it is normal today. I will keep posting if that happens again. Only difference is PT control isn't connected today. I will do it later today.
Old 05-22-2016, 01:45 AM
Mark Ziebarth Mark Ziebarth is offline
In the app set file there's the possibility to set the font size via a simple text editor. I did it for the soft keys pages in the PT Control app. Worked fine.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 05-22-2016, 06:41 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Originally Posted by hj0102 View Post
Hello,
This will happen when you have two monitors and the EuControl Settings window is dragged to the second monitor. It happens because the drawing for the OLEDs is happening at a different resolution on the second display before being pushed down to S3. The workaround is easy:
1. In EuControl Settings, move S3 from "My Surfaces" to "All Surfaces" list
2. Drag EuControl Settings window back to your computer's primary display
3. Move S3 from "All Surfaces" back to "My Surfaces" list
If you always keep EuControl Settings on your main computer's display this issue should not occur again.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 05-30-2016, 03:25 PM
Thanks,
It happened again, but after I turn on MC Transport it back to normal. I guess if there's control for font size, it will be nice.
Thanks
Old 06-01-2016, 07:20 PM
Thanks,
Thanks
Do you have two monitors? That's where we've seen this issue. And if so, which monitor do you have the EuControl Settings window on?
Kyle Splittgerber
Berkeley, CA
Old 06-05-2016, 05:44 PM
I have 4K, 29" wide monitors. When this thing happens, I just turn off 4k and back on. I hope there's simple solution on control. thanks
Old 06-06-2016, 12:08 PM
Simple solution is mentioned in my first post. Is that not working?
Kyle Splittgerber
Berkeley, CA
Old 08-06-2016, 08:39 AM
jyang jyang is offline
Just wanted to add to this that I am also experiencing this bug, and Kyle's workaround fixes the issue. 10.11.3 on an Retina Macbook Pro with a secondary display vs HDMI.
I move the Eucontrol settings to my laptop's display and remove the unit and it automatically re-adds itself and is fine.
Annoyingly though I have to do this everytime I load it up as I use an external monitor as my main display so the Eucontrol window defaults to this one. Be great to see this fixed in an update soon!
Old 01-03-2019, 09:15 AM
littlesicily littlesicily is offline
This error just started for me the other day. I do have two monitors. I'm not sure I understood these instructions. Nothing changed for me and font is still very small.
EuControl 3.7.0.138 on OS 10.14.2. PT 2018.12
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1
Font size. r.heyman Pro Tools 11 2 03-01-2015 05:29 PM
Increase Font Size garden rock studios Pro Tools 9 6 04-06-2011 06:38 PM
Change font in Pfreferences display matthewacacia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-31-2009 04:21 PM
Increasing font size? MboxToo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-06-2009 06:20 PM
Increasing display font size MboxToo Tips & Tricks 1 05-06-2009 06:17 PM
