Old 10-20-2021, 02:03 AM
rantanplan rantanplan is offline
Default Waves Central sees no USB flash drives after update
Hi there
Anyone else who has this problem?
On Windows 10, Waves Central automatically updated to the latest version when i launched it yesterday.
I wanted to move all my licenses from the cloud to a USB flash drive. But Waves Central doesn't show any of the USB drives I connected. They were all FAT32 formated. I reconnected them several times and even re-formated one of them. Still no success
I need the licenses on a flash drive because I'm still using Pro Tools 10 on OS X 10.9.5.
Now I can't continue work
I couldn't find this issue on Waves FAQ. I will write to support, but I don't have much hope that they answer soon.
Cheers
T
Old 10-20-2021, 08:27 AM
Default Re: Waves Central sees no USB flash drives after update
I would open a support case with Waves, traditionally, they respond fast in the middle of a week(in my experience, I have had replies from them within hours) It may also be worth going to the nearest Staples or Best Buy and buying the smallest USB memory stick(smallest because Waves needs almost zero space on the drive, but buy whatever size you like). FWIW, I have had 1 or 2 of these things just quit for no good reason.
Old 10-20-2021, 08:29 AM
If things are still not happy, I would uninstall Waves Central, then download and install the latest(the fact that WC is not finding a USB stick suggests that the WC install is corrupt). Last thing to try: If you have Samsung Magician software installed, remove it(in the past, this has caused all USB drives to disappear for me).
JFreak's Avatar
JFreak JFreak is offline
Also worth checking if it works on Mac, so long as you have the licenses on the stick it does not matter which machine you used to put them there. Maybe it is a Windows problem?
Janne
Old 10-20-2021, 11:15 AM
Hi
Thank you very much for your hints.
I'm quite sure that the USB flash drives are ok. I tried more than one and they all work fine for storing stuff on it. And one of them is also used for Plugin Alliance authorization, and there's no issue with that.
A month ago or so I did the same thing with the same stick and it worked fine. But no luck after the update of WC.
I think it's really an issue with the latest version (this came by auto-update when I started Waves Central), or maybe with a recent Windows update.
WC simply doesn't react to any USB flash drive on Windows anymore.
On OS X it says "syncing... don't disconnect USB flash drive" whenever I plug the stick. But this is a legacy WC version. And sticks activated with it didn't work with Pro Tools any longer.
Sadly I don't have any recent OS X where I could run the latest WC. I stick with PT 10 HD because of all the PT hardware (controller, I/O...).
I will try to completely uninstall all Waves stuff and then give it another try.
Cheers
T
Old 10-20-2021, 12:22 PM
EGS's Avatar
EGS EGS is offline
It's working as expected here. Try This: https://www.waves.com/support/move-licenses
Desktop: PT 2020.5 / Win 10 / Intel i9-11900K / Gigabyte Z590 Vision D / 64GB DDR4 / Focusrite LS56
Laptop: PT 2020.5 / Win 10 / Intel i7 / HP ProBook / U-PHORIA UMC1820
Legacy: PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for demo
Old 10-20-2021, 04:00 PM
Hi, thanks for the link. This is exactly what I'm trying to do. But it's not possible when the USB flash drive is not showing up in the Waves Central...
Old 10-21-2021, 08:00 AM
Good news:
I just got a mail from Waves:
Thank you for the detailed information.
We are familiar with the issue you've mentioned and are working to fix it.
We found that this issue occurs in non-English systems.
In the meantime, I have uploaded a special version of Waves Central that should address this issue.
Follow the instructions below to apply the fix:
Please go to THIS LINK
Upon clicking the link, under Enter Verification Code, click Send code.
You will receive an e-mail with a temporary code for verification to your inbox. If you can't see the e-mail, please check the spam folder.
Copy and paste the code to the text-box and click Verify.
You can now download the file.
Install Waves Central
My thanks to everyone here for the support.
I guess that there will be a new version soon.
I'm not sure if I'm allowed to share the mentioned link here.
If someone has the same issue he can send me a PM or better write a mail to Waves.
Cheers
T
HTML code is On
Pro Tools missing V9 plugins from Waves after updating Waves Central williamg AAX Plug-ins 4 12-14-2019 06:54 AM
Waves Central must update? musicman691 AAX Plug-ins 4 04-12-2016 05:33 AM
eSATA flash drives algerij 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-20-2011 06:53 PM
eSATA Flash Drives AKProductions Storage Subsystems 4 03-15-2010 01:14 AM
USB 2.0 Flash drives? mpark9000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-06-2004 03:40 PM
