PT 2021.7 & AAE-9178 error
Hello!
Just installed PT 2021.7 and got an AAE-9178 error as it tried to load the FM8 synth from Native Instruments' Komplete suite. Uninstalled FM8, PT loaded fine. All the other plugins from the suite load correctly. Reinstalled FM8, got the error again. Uninstalled FM8, all is well... Any clues? Thank you! Here is the info on my system: Operating System Windows 10 Pro 64-bit CPU Intel Core 2 Quad Q9400 @ 2.66GHz 37 °C Yorkfield 45nm Technology RAM 8.00GB Dual-Channel DDR2 @ 332MHz (5-5-5-15) Motherboard Dell Inc. 0M858N (CPU) Graphics DELL 1707FP (1280x1024@60Hz) HP 27w (1920x1080@60Hz) Intel Q45/Q43 Express Chipset (Dell) Intel Q45/Q43 Express Chipset (Dell) Storage 111GB KINGSTON SA400S37120G (SATA-2 (SSD)) 27 °C 465GB Western Digital WDC WD5003AZEX-00RLFA0 (SATA ) 32 °C 1397GB Seagate BUP Slim SL SCSI Disk Device (USB (SATA) ) 30 °C Optical Drives TSSTcorp DVD+-RW TS-H653G Audio Yamaha Steinberg USB Audio Last edited by dramis; 08-12-2021 at 02:50 PM. Reason: Provide system info |
Re: PT 2021.7 & AAE-9178 error
Ask NI
Thanks. Will do.
The amount of help you get is directly proportional to how much system info you provide.
Thanks. I agree. Just added the info to original post.
You are WAY under spec on this. Pro Tools says 16GB ram minimum, you’re at half the minimum. They also suggest an i7 (although some users are getting by just fine with an i5.)
A Google search says a 9173 error happens when you’re over-taxing the processor. |
Yes, I saw about the RAM. Just strange that only one of the NI suite of plugins would create a problem. And it was a 9178 error, not the 9173. The former is way less documented. If this is a hardware problem, I will upgrade.
These NI Virtual Synths take a lot of CPU to work and loads into the RAM memory so I would ask on the NI bosrd first, then i would get atleast 2X16 GB ram sticks (have to be the same make and model) so you can get the system up to par. The i5 is not an issue here but i think there might be a comflict somewhere on the system. I loaded up the same synth on an older laptop we had in a closet with win 10 and 8 GB ram and it works perfectly so my guess is that either an older version is still on the harddrive or some other conflict. Maybe you need to reinstall the offending synth as it could become corrupt.
Thanks for your help! |
When you use a 12 year old cpu, each software update will bring you one step closer to the edge.....
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100 |
Protools First: AAE-9178 Error | SYDZ | Pro Tools | Intro Discussion | 3 | 04-24-2020 11:00 AM |
AAE-9178 Error | Patshill | AAX Plug-ins | 0 | 06-04-2018 02:30 AM |
AAE Error -9178 | JimGriffith | Pro Tools 12 | 3 | 12-15-2017 05:50 AM |
AAE Error -9178 | JayRosa | Windows | 1 | 07-29-2017 01:28 PM |
Getting AAE error -9178? Here's what worked for me. | mesaone | Pro Tools 12 | 0 | 12-08-2016 11:52 PM |
