MC Control touch button active window under Cubase 8
Hi to all, I've notice recently that some functions that I have previous assigned to my MC control touchcreen, working fine only if the interested window is active....I mean, I've made a button with the Q-Link function, that's for me is a lot useful, but If the mixer window is not active the button doesn't work. The same thing for the 'full zoom' button that works only if the project window is active.
This way is very annoying cause we are forced to use the mouse to activate the interested window and then press the button..... Is there the way to made always active all the windows? (i have 2 monitors, one for the project and one for the mixer win). Otherwise is there a way to fix it in the eucon settings?
WIN 11 64 bit Cubase 12 MC Mix and MC Control V2 EuCon 4.17.2.121 Eucontrol 2023.11.0.121 |
Re: MC Control touch button active window under Cubase 8
This is apparently a Steinberg issue. I'm a Nuendo user and we have the same complaint, especially since they've updated to Nuendo 7. The multiple window platform is driving a lot of us nuts. We suspect that this was done for Nuage hardware intergration. But if you don't have Nuage............... well, too bad for you.
At present, nobody has found a work around for this issue. The closest any of us has come is (wherever possible) doubling the commands. For example, when I used the softkey to open a channel for editing, it would only open in the mixer window IF I had the mixer window active. If I was in the project window, the channel wouldn't open. The opposite was also true. So, I had to make a seperate button for each to do THE EXACT SAME FUNCTION. If I open the channel in the mixer, I had to select the "mixer button." But if I wanted to open the same channel from the project window, I now had to select the "project" button. This is a ridiculous waste of time (programming 2 buttons to do the same thing) and resources (the 2nd button takes up the place where you could really use another button doing a different function). But at least we have the option. Those folks not using any kind of controllers are really upset about this active window nonsense! |
REQUEST: Add group and master touch button | fenders74 | Artist Series | 0 | 07-03-2014 05:53 AM |
Touch to select on MC mix, does control touch screen follow? | Led | Artist Series | 0 | 03-24-2011 05:36 AM |
AudioSuite up with a touch of a button | Ryan Young | ICON & C|24 | 3 | 09-18-2010 11:47 PM |
Autowrite/touch/latch not working on mix window | ilianarose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-08-2007 06:17 PM |
recording with the touch of a button | Layne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-08-2002 05:17 AM |
