Old 06-08-2008, 02:45 PM
BWEL BWEL is offline
Default Problems with playback - nothing showing on peak meter
Hi there, I'm new to ProTools and using a 003 Factory. I've recorded my first audio track and think I've correctly assigned the send to Analog 1-2 which I think also equates to the monitor output. However there is no sound from the audio track I've recorded - only from the click track which is also sent to Analog 1-2.
The waveform shows the audio data correctly but the peak meter doesn't move - I don't know enough about this whole thing to be able to identify where I'm going wrong so would be hugely grateful for any suggestions you might have.
M
BrickWallElectricLight
Old 06-08-2008, 05:29 PM
Phil Ogden Phil Ogden is offline
Default Re: Problems with playback - nothing showing on peak meter
M
Just to be sure,
1. Track OUTPUT (not send) is set to analogue 1&2, right?
2. Is the Fader turned-up?
3. Is the track muted or other channels soloed?
4. Can you audition the audio file in the workspace browser?
http://www.myspace.com/philogg
Old 06-10-2008, 01:26 AM
mrjohn mrjohn is offline
Was the track still record enabled when you tried to play it back? If you have 'Input only Monitoring' selected in the track menu this would stop you hearing it as that track would still be in input monitor mode.
John
Mac Pro 2 x 2.8GHz Quad
OSX 10.10.5, PTHD 12.4.0
Old 06-10-2008, 08:02 AM
flommer flommer is offline
I'm concerned about this statement... Are you actually talking about the sends section of the channel strip in the mix window? By default, an audio track's output will be assigned to outputs 1-2 (main L-R) so you shouldn't have to assign anything. The sends are (usually) for "sending" the audio to a different aux or output for some type of processing before bringing it back into the mix.. Other than that , the other 2 posters comments should get you hearing the audio..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 11:49 AM
Meter Peak Hold, please! Doctor Faust System 5 0 10-20-2010 01:52 PM
Peak meter not responding? luqiao Pro Tools M-Powered (Mac) 3 12-26-2009 04:33 PM
which peak meter? evs Post - Surround - Video 8 09-04-2008 10:48 AM
LED METER PEAK HOLD Gaffer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-19-2002 11:07 AM
