Old 11-15-2005, 01:54 PM
ouijibill ouijibill is offline
Default Meter Problems in PT 7
Meters for audio tracks are still active when muted and faders are turned off, furthermore the meters dont seem to correspond with the audio material dedicated to the track when they are muted and turned down .
I have pre fader metering turned off.
I am using a Mac dual 1.8 with 1.5 RAM OS X 10.4 PT7
Any suggestions
Old 11-15-2005, 04:45 PM
Amo Audio Amo Audio is offline
Default Re: Meter Problems in PT 7
I'm also having this problem. I am also hearing occasional clicks and pops from either the left or right channel (but never both at once) which never occurred under protools 6.9.2.
Dual 2ghz G5, 200gb system drive, 400gb audio drive, osx 10.4.2, Digi002.
www.amoaudio.com
Old 11-15-2005, 05:56 PM
DigiTechSupt's Avatar
Have you tried all the suggestions in the OSX Setup and General Troubleshooting thread yet, specifically trashing prefs and databases?
Avid Audio Tech Support
Support FAQ
Old 11-15-2005, 06:58 PM
Trashing Pref and Volumes worked.
cheers
Inserts affecting send meter but not channel meter? Kbrinson85 Windows 1 05-01-2012 08:00 AM
Problems with SRC 1 (3-4) meter dcdave ProControl, Control|24, Command|8 0 12-06-2010 10:03 AM
Problems with playback - nothing showing on peak meter BWEL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2008 08:02 AM
Problems: Latest Tiger Update, Crazy CPU/RTAS meter. Kevin_Cheung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-06-2008 01:18 PM
Meter problems oneblood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-26-2004 08:17 PM
