Old 05-11-2013, 08:27 PM
cc1 cc1 is offline
Default Request for basic help
I'm trying to get a system working and can not seem to get input level coming into PT. What I'm using:
PT HD 7.3.1
Apogee Rosetta with XHD card (using analog IO)
Lunchbox with some 512 mic pres
Power PC G5 10.4.11
Playing audio in PT I get signal from the Rosetta to my mixer - but I cant get input level showing in PT from the 512's. PT's IO setup looks good. I tested a 512 out to my mixer and it works. Havent used PT in a few years. Thanks so much for any comments! -c
Old 05-13-2013, 01:51 AM
Stig Eliassen's Avatar
Default Re: Request for basic help
Have you read this setup guide? There are explanations on how to configure the hardware and I/O setup in Pro Tools.
http://www.apogeedigital.com/pdf/xhd...usersguide.pdf
How about firmware? Is it "current" for the setup you have?
Old 05-13-2013, 03:48 AM
JFreak's Avatar
JFreak JFreak is online now
You need to set the Rosetta to "option" which means XHD card that goes to PT.
You also might need to toggle the sample rate and clocking buttons a little, at least my XHD card was not instantly recognized. Once you get it going the first time, the settings should be remembered.
Janne
Some Basic & not so Basic Copyright Info everone should know. DrFord General Discussion 3 11-07-2010 04:49 PM
...some basic questions needing basic answers aponceenrile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2010 10:48 AM
Basic, basic recording question enigami MIDI 1 06-08-2009 06:27 PM
Basic mBox set-up help request eldangeroso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-23-2004 02:37 PM
Basic Pro Tools use. Really Basic question. Shizznik_McRuube 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2002 11:41 AM
