Old 11-12-2007, 04:08 PM
cc1 cc1 is offline
Default quick way to A/B a session with reference track...
currently -for me to A/B a SESSION with a REFERENCE TRACK i have to do the following:
to hear ref-track:
> unmute the ref-track and solo it
then to hear the session:
> unsolo ref track and mute it
then to hear the ref-track again:
> unmute the ref track and solo it
etc
is there a way to press one button to switch back and forth between the session and ref-track ? -c
Old 11-12-2007, 04:59 PM
blackmacdaddy blackmacdaddy is offline
Default Re: quick way to A/B a session with reference track...
to hear ref-track:
> unmute the ref-track and solo it then to hear the session:
> unsolo ref track and mute itthen to hear the ref-track again:
> unmute the ref track and solo itetc
Perhaps as a workaround this will help, depending on what you are doing:
Instead of using dynamic voice allocation, assign both the reference track & the Session track to the same pair of voices.
Now, whichever track is "left most" in your session in
the edit window will be the only one heard.
I'm not in front of my HD rig right now, but I've also got an idea that may help even more. I'll re-post in a few hours if it's 'one better'....
Best ;-)
Walt
It's only R'n'R but I like it.
Old 11-12-2007, 05:10 PM
Andre Knecht Andre Knecht is offline
Have all your session tracks routed to one AUX which outputs to your monitoring path. Set the output of the Reference track to the same monitor path as above. Now you can “solo” one or the other. (Make sure that your solo setup is non-latching.)
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 11-12-2007, 07:33 PM
JDH10 JDH10 is offline
What are you monitoring your mix through. If you have something with different sources, you can send the ref mix out an unused set of outputs and have those going to a different monitoring input, then switch back and forth on that.
If not then you can make a group with all that tracks except the reference track and solo (non-latching) between the two.
Old 11-12-2007, 10:35 PM
The_Moodio The_Moodio is offline
Duplicate the reference track. Then flip the phase on one off them. So..... When you press play the now 2 Ref. tracks cancel each other out and leave just you mix. Then simpily Solo one of the Ref. tracks to compare it to your mix. Remember that if you want to change the level of your Ref. track (as it will most likely be mastered) that you have to adjust both tracks so grouping them is the best for keeping things simple. Hope that helps.
Old 11-12-2007, 11:34 PM
Steve MacMillan Steve MacMillan is offline
I usually have all my topmost tracks routed to a stereo buss which feeds an aux assigned to output 1-2. When I'm ready to print, I route the aux to my print busses instead, and they go to a print track that feeds output 1-2. So if you have a reference mix on your print track, all you have to do to compare is toggle the input button on the print track.
STeve
macmandigital.com
Old 11-14-2007, 01:11 PM
Stig Eliassen's Avatar
I use a method where I duplicate the reference track, and invert the phase of the duplicate (AudioSuite menu > Other > Invert). All tracks in the session are routed to a stereo aux (PreMaster), including the reference track(s).
Normal playback - I hear all tracks except the reference track because the phase-inverted duplicate cancel it out.
Control+5 (numeric) - this is the shortcut to shuttle forward at normal speed. Hit spacebar to stop. Hit spacebar again for normal session playback. I can toggle between session and reference this way pretty easy.
To prepare for this method I simply click in the reference track with the selector tool where I want playback to start. Ctrl+5 (Mac) shuttles the reference, and spacebar starts session playback.
Old 11-14-2007, 04:14 PM
sleadley sleadley is offline
The way I do this is to use VCA'S and unlatch the solo bus.
1. create a group and a VCA for the ref Track then assign the VCA to that group.
2. Create a group and a vca for the New Track (or tracks) the VCA to that group.
3 make sure that the solo pref is set not to latch. X-OR in the Solo Options
Then you need only select the solo on the VCA of the REF track or the main track to compare. Pressing one cancels the solo of the other. This does not require routing to AUX's and is simple to set up.
How much do we love VCA's?
hope this helps
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 11-16-2007, 08:34 AM
Tom Pfaeffle Tom Pfaeffle is offline
Have all your session tracks routed to one AUX ( put some mastering plugs, L2007 etc on this) which outputs to your monitoring path. Set the output of the Reference track to the same monitor path as above. Then- move your ref track down the timeline past your song- write a marker on your ref track (verse- chorus) bring up the marker window (apple-5)
Click away.
Quick set up with Fast Track Pro? frcjt macOS 3 03-12-2011 01:28 AM
MIDI track routing to Aux track quick question Mason00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-28-2006 08:30 AM
Applying a 'reference mix session': possible ? seth666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-20-2005 04:27 AM
Reference levels-quick question TheVectorWarrior Post - Surround - Video 2 07-05-2005 06:50 AM
EQ quick reference... pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-12-2002 09:04 AM
