By holding option I added Phoenix plugin across all
tracks. Now can I change the parameters of all 39 instances of the plugin at one time? for instance changing from "gold" to "sapphire" for all Phoenix instances... or do I have to do it one track at a time -which is impossible for me to really A/B. Also can I "bypass" all 39 instances of the plugin at once? Tks
Re: By holding option I added Phoenix plugin across all
Yes, no worries. Just assign all 39 channels to a group. On the group assign window, go to attributes and de-select 'Follow Globals". Then check the box under controls for the insert the Pheonix plug-ins are on. Rock on.
macmandigital.com |
You might want to read the “Setting Group Attributes” section in the “Tracks” chapter of your reference manual.
IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
tks steve & andre, one more thing:
the mono tracks all change together but the stereo tracks don't follow along (the opposite is true too -the mono's don't follow along when a stereo plugin setting is changed) -is it possible to tie mono and stereo together? tks again |
That's going to be more a problem with design of Phoenix I think. (Or maybe all plugs - you might want to check). It appears that the mono and stereo versions see themselves as totally different plugs. I wonder if you used multi-mono versions on your stereo tracks if that would help? More analog too!
Cool & Informative Video Tutorials from Groove3 |
Plugin-Processed sound file added names list ? | flukux | macOS | 3 | 03-03-2014 11:43 AM |
can't find phoenix plugin. | Daniel Ellis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-31-2010 04:47 PM |
6031 is it fixed? “Don’t Show This Again” Option Added to Some Error and Warning Dial | Venture Studios | Pro Tools TDM Systems (Win) | 25 | 12-22-2009 07:33 AM |
Alternatives to Cranesong's Phoenix Plugin?? | Camilo Orozco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-01-2009 12:19 PM |
Cranesong Phoenix analogue plugin recommended | crizdee | Pro Tools TDM Systems (Mac) | 5 | 06-02-2005 08:23 AM |
