Old 05-07-2007, 09:25 PM
cc1 cc1 is offline
Default Import Session Data (PT 7.3.1)
Tried to import session data from a session (call it session1) -when it imported the one audio track, the track was created but no audio was imported (empty track). I tried opening up another session and then importing one track from session1 and the same thing happened. Then I tried making a "save copy in" copy of session 1 and the same thing happens when trying to import one track from (copy of session1). This never happens when I try to import session data from other sessions. I also looked at the format, sample rate. bit depth of all sessions and they were the same... tks for help...
Old 05-08-2007, 01:24 AM
Horsewater Horsewater is offline
Default Re: Import Session Data (PT 7.3.1)
It did the same for me !
I've tried to import 2 tracks from a 7.1.1 session into a 7.3.1 session.
I've had both of them but no media (I've tried many setup in the import data sessions page ....)
I thought it was an issue between versions 7.1.1 and 7.3.1 because I've done a lot of import session data between "7.3.1" sessions with no issue at all.
I hope it helps.
Composer / Sound Engineer
www.oupaproductions.com
G5 2x2.7 / 7Gb RAM / 10.4.9 / PTHD 7.4cs8
Old 05-08-2007, 05:31 AM
ilovemyssl ilovemyssl is offline
FWIW, somewhere around 7.x Import Sessions Data has gotten totally screwed. I have posted on this a few times, but no word from Digi. I have had it stuff up, and then re-try the same thing and it work properly.
There are other issues with it like telling it not to import the Output Assignments and it still does... importing tempo maps only works half the time etc etc.
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix
2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1
SSL 4056G
Old 05-09-2007, 09:54 AM
OliJ OliJ is offline
Have you checked to see wether the session start times are the same? This has given me a similar problem in the past.
HD1 2.26 8 core Nehalem PT9.05 OSX10.6.8
Old 05-09-2007, 06:17 PM
I have observed this phenomenon on a v7.2cs1 system we have. The way I kind of got around it was to create a fresh session and import into that (fresh as in not from a template). I suspect the true fix is not that simple though. I probably just got a stroke of luck. Maybe if we cull enough data together we can figure this one out?
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 07:53 AM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
End of Stream Reached - session broken - import session data does not work... Sean Russell Pro Tools TDM Systems (Mac) 0 01-15-2010 04:56 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
