Old 04-27-2022, 07:33 PM
Ken P Ken P is offline
Default MPC Beats, Mpk Mini / Octopad Midi controllers
I am using MPC Beats as a plugin and can't figure out how at one point I had both an Mpk mini as well as a Roland Octopad connected and able to trigger pads/notes in the mpc beats plugin. when i close PT, I can open mpc beats stand alone and the mpk mini controller works but not octopad. I feel like a certain powerup sequence or something made it work but I cant seem to find it.
all controllers are checked as midi devices, when i open a midi track in pt and record enable, both mpk mini and octopad trigger levels being received in the midi track, and output is assigned to Mpc beats, etc - can't get mpc beats to receive mpk pad triggers or octopad triggers. has anyone had luck with a similar setup?
Ken P.
Pro Tools Ultimate, Mac Mini 3.2 i7, Mtrx Studio & Omni, 4x S1’s & Dock w/ iPad Air 2
HTML code is On
Not seeing MIDI controller (Akai MPK249) under Peripherals > MIDI Controllers Focuret Pro Tools 12 0 05-18-2017 11:22 AM
Midi Predifined options in Peripherals\Midi Controllers menu RuffinMedia macOS 3 03-04-2015 04:54 PM
Mbox2 Mini and HP Beats Laptop takieddo Pro Tools 9 2 10-02-2011 05:26 PM
Roland Octopad ll Midi Pad Controller Hamdi The Drum Room 3 01-03-2011 08:18 AM
Need advice! Mbox 2 mini with midi controllers TrustoneR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-09-2007 06:20 AM
