Old 05-11-2022, 07:35 AM
Carl Lie Carl Lie is offline
Default Re: Where are my clips?
Originally Posted by Mixmaster Rick View Post
For each of these three tracks I created an Aux Track into an Audio track.
Thank You!
This is the part that doesn't make sense and where it seems you are making it more complicated for yourself than need be.
Perhaps elaborate on this process further and then we should be able to help.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 05-11-2022, 07:49 AM
Mixmaster Rick Mixmaster Rick is offline
Good advice for all I suppose.
Thanks!
Pro Tools Studio 2023.12.1, Mac Studio 2023 M2 Ultra, 64GB RAM, macOS Ventura 13.6.4 (22G513), UAD Apollo X8, Apollo x6 x2, UAD-2-Satellite-TB3-Octo, UAD-2-Satellite-TB3-Quad, Avid Dock w/ iPad Pro 12.9", Avid S1 x 2 w/ iPad Air 10.9", Neumann KH 310 w/ KH750 Sub, Genelec 8320A, Adam Audio T7V w/ Sub8, G-Technology TB3 x 6
Old 05-11-2022, 07:54 AM
its2loud its2loud is online now
He’s routing audio through an Aux Track to record onto an Audio Track. It’s not uncommon. It’s not that complicated and doesn’t really mess anything up as long as the bussing is correct, which it seems it was.
Rick, it’s confusing what the problem is exactly because the explanation isn’t very clear, no offense.
Darryl is suggesting that you “lost” the clips on the timeline because you’d moved to a different location and you’re zoomed in. It can be a big workspace sometimes.
It’s also possible that you’ve inadvertently hidden the original track you recorded on or deleted the clips off the timeline by accident.
In either case the recordings are not gone, like you discovered. Therefore, determine if any of the above is true and if so, you can correct. If you need to put the clips back on a track simply drag them from the clip list and all will be whole again.
Old 05-11-2022, 08:01 AM
Hi Darryl,
Thanks for your time on this. I honestly had no idea that DUC was downscaling my attachments...now I know.
its2loud's comments are spot on. I wanted the flexibility to add plugs to the Aux track and route to the Audio track which is working fine. Again, I transferred ~100 tapes with this same template without any issue.
I'll just create a new session for this and start again. I appreciate all of the input, seriously I do so thanks to all.
Old 05-11-2022, 08:49 AM
Hi Darryl,
Rick, when you say start again do you mean from scratch? Recording the 100 tapes again? If so, that’s not necessary as long as the Pro Tools recordings exist.
Pro Tools corrupts clips - swaps audio with different clips jgiannis Pro Tools 12 5 11-23-2020 08:30 PM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Cross fades are not between clips but at the end or beginning of clips phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 2 09-10-2012 02:08 AM
Drag Clips = Delete Clips??? Connor macOS 2 07-09-2012 07:50 PM
Editing clips without creating new clips dimebagslash Pro Tools 10 2 07-04-2012 07:24 AM
