Did Zoom change something on a recent update? We usually use Audiomovers to send audio to client and PT Bridge 2B to hear back. I tried to send audio to Zoom via PT Bridge 2A and it only intermittently works and poorly at that. I use PT Bridge 2B 24/7 to monitor from Logic Pro without as much as a crackle.
We have two HDX systems and I tried it on a know working system however, Zoom updated upon launching and it too doesn't send audio via Bridge 2A. In "settings" audio tests OK for playback but no input-level even when sending a full-scale test tone from PT. Both systems are on 6,1's running Big Sur 11.5.2; PT 2022 9.0. Any suggestions as I've found only one thread on Zoom Support. Thanks! Last edited by RayCervenka; 11-12-2024 at 03:59 PM. |
Try clearing your Pro Tools cache and see if the same issue occurs.
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Thanks for responding.
Cleared the PT cache. Deleted all I/O and set to default. Swapped the Bridge 2A/2B paths. Rebooted with just PT and Zoom up. Still nothing. Logic Pro working with swapping the paths. Zoom does receive audio from my USB webcam. I probably should just get out of the stone-age of Big Sur and update the OS. Cheers! |
Pro Tools 2023.3 - UI/Clip Zoom/Waveform Centerline Issue | ZoaSoundworks | Pro Tools | 4 | 04-15-2023 07:03 AM |
Pro Tools 12.6.0 Zoom Issue | AcousticAddiction | Pro Tools 12 | 5 | 02-08-2017 05:36 PM |
Digi 003 input from pro tools OK, output issue | elusername | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-15-2013 08:45 AM |
Zoom H4 as input for PT 10 | Skybreak | Pro Tools 10 | 3 | 02-22-2013 01:50 PM |
ADAT Bridge 24 - any wordclock input ? | Haniel Trisna | Pro Tools TDM Systems (Mac) | 17 | 12-16-2001 03:31 PM |
